20 Dec 2015, 15:13
Buna ziua.
Am un seat altea 2005 BKD 140 CP. Mergea fara probleme.. pornea ls sfert.. etc pana azi dimineata.
Am bagat cheia.. invartit si nimic.., nu misca nimic in bord si nici o lumina.,. dau cheie. porneste o secunda moare si tot asa..
se uita cineva pe o scanare VCDS (care ciudat merge) - si poate sa ma ajute cu un sfat, idee??
mai mentionez ca bateria este de iarna trecuta si e buna.. toate celelalte chestii din masina merg - clima, ventilatoare, faruri, claxon etc.
multumesc
Sunday,20,December,2015,14:34:23:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
License Plate: MORT
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
VIN:
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FH HW: 028 101 190 9
Component: R4 2,0L EDC G000SG 6185
Revision: 12345678 Serial number: SEZ7Z0D2424106
Coding: 0050072
Shop #: WSC 06402 785 00200
VCID: 6ED328337962DE6E76F-803B
3 Faults Found:
18104 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
Freeze Frame:
RPM: 1932 /min
Torque: 0.0 Nm
Speed: 63.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11001011
Bin. Bits: 00000000
(no units): 1.0
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster
Freeze Frame:
RPM: 0 /min
Torque: 230.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.87 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 160.0 Nm
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 230.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.79 V
Bin. Bits: 00101100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023282
VCID: 3A7BD46375AA42CE9A7-806F
1 Fault Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 004 0202
Shop #: WSC 00000 000 00000
VCID: 2F6DF537BEE897663D9-807A
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal
01317 - Control Module in Instrument Cluster (J285)
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001216630
Coding: 81880F2700041000001E00000000000000
VCID: 387FCE6B4BA650DE6C3-806D
Subsystem 1 - Part No: 5P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0401
Coding: 00056272
Shop #: WSC 00000
No fault code found.
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: S3 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0EHG98
Coding: 0021299
VCID: 2D51EF3FB4E4E5760F5-8078
Subsystem 1 - Serial number: 6332MSME6A636203
Subsystem 2 - Serial number: 6342MSME457C7803
Subsystem 3 - Serial number: 6351HSME694E0D03
Subsystem 4 - Serial number: 6361HSME464E0D03
1 Fault Found:
004 - No Signal/Communication - MIL ON
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002042
VCID: 3169F34FA8DC81962BD-8064
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective - Intermittent
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001045164242
Coding: 3D3F0B00078202
VCID: 275D1D179618CF26F59-8072
2 Faults Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 234
Time Indication: 0
Date: 2000.00.00
Time: 08:38:28
00381 - Databus Instrument Cluster
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 19
Reset counter: 194
Time Indication: 15
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 3561C75F5CB4ADB6775-8060
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.13 1401
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 99C000BC2D000D0D4C4F867000
VCID: 7BF511673A10BBC6C11-802E
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 3663C05341B2A6AE7EF-8063
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Component: Tuersteuergeraet 06 0206
Coding: 0000016
VCID: 306FF64BA3D6889E243-8065
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
