musat ionut
erori pe vag com
18 Apr 2010, 18:07
Salut tuturor.Sunt nou pe forum si am nevoie de un pic de ajutor.Cine imi poate spune ce inseamna erorile astea aparute la un test vagcom pe ibiza mea.Multumesc
Control Module Part Number: 03E 906 033 D
Component and/or Version: 1,2l/4V SIMOS3 00HS4342
Software Coding: 00021
Work Shop Code: WSC 06402
Additional Info: VSSZZZ6LZ2R043137 SEZ7Z0B1560483
3 Faults Found:
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0010 0000
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 6Q1 937 049 B
Component and/or Version: BORDNETZ-SG. 1S31
Software Coding: 16396
6 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
01044 - Control Module Incorrectly Coded
35-00 - -
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00907 - Intervention load Management
35-00 - -
ibiza 1.2 coupe
musat ionut
Re: erori pe vag com
22 Apr 2010, 07:07
nimeni?
ibiza 1.2 coupe
Trainelu
22 Apr 2010, 08:38
ALTEA XL 1.6 STYLANCE
ZENITH GREY
musat ionut
22 Apr 2010, 14:28
ibiza 1.2 coupe
