Agnesleon
Aprins esp, check engine cateodata
05 Feb 2018, 09:00
Buna!
Am un Leon 1.6 benzina din 2006 si de cateva luni mi se aprinde esp-ul odata din 10porniri si check-engineul cateodata..am facut o diagnoza si imi da eroare de ceva senzor de la motor (a fost schimbat senzorul deci probabil nu e aia) masina merge bine, trage cum trebuie..poate consuma unpic mai mult decat trebuia dar nu exagerat..Multumesc de ajutor!
Agnesleon
Re: Aprins esp, check engine cateodata
12 Feb 2018, 09:12
Sunday,04,February,2018,18:09:38:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ1PZ6R095163 Mileage: 143400km/89104miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: None
Part No: 06A 906 033 FF
Component: SIMOS71 1.6l 2V 7004
Revision: --H01--- Serial number: SEZ7Z0F3389614
Coding: 0000071
Shop #: WSC 06401 785 00200
1 Fault Found:
16719 - Crankshaft Position Sensor (G28): Malfunction
P0335 - 009 - Open or Short to Ground
Freeze Frame:
Bin. Bits: 00000001
Voltage: 0.000 V
Voltage: 2.280 V
Voltage: 2.280 V
Bin. Bits: 00000001
Voltage: 0.000 V
Voltage: 2.040 V
Voltage: 2.040 V
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441 785 00200
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004030420
Coding: 018C0F2F00041000001D00000000000000007F075C
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
1 Fault Found:
00985 - Right Tail Light (M2)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 29
Reset counter: 55
Mileage: 142283 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R3 AIRBAG VW8 027 2521
Revision: 09027000 Serial number: 003A1P38Y9RY
Coding: 0021043
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002002
Part No: XXXXXXXXXXX
Component: E0221 005 0060
Part No: 1P0 920 804 B
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0000101
Shop #: WSC 80093 222 69422
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106405810E
Coding: 3D0F0340070202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2395
Coding: 0000176
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC09000505484B090004CC
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000176
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186
Component: Radio BVX 0017
Coding: 0040400
