Cox-Leon
Localitate: Moinesti
Racire Apa PC Water Cooling ( CPU + GPU ) ID HUNTER DUET
10 Oct 2017, 08:02
Compatibilitate Socket
Intel LGA 775 Da
Intel LGA 1150 Da
Intel LGA 1151 Da
Intel LGA 1155 Da
Intel LGA 1156 Da
Intel LGA 2011 Da
Intel LGA 2011-3 Da
AMD AM2 Da
AMD AM2+ Da
AMD AM3 Da
AMD AM3+ Da
AMD FM1 Da
AMD FM2 Da
AMD FM2+ Da
General
Tip racire Lichid
Racire Activ
Bearing ventilator Hydraulic
Inaltime 27 mm
Numar ventilatoare 2
Dimensiune ventilator 120 mm
Viteza de rotatie ventilator Pump: 2500 RPM
Fan radiator: 800 - 2000 RPM
Fan waterblock: 1500 RPM
Dimensiuni radiator 274×120×27 mm
Conector ventilator 4 pin
PWM ventilator Da
Flux aer 84.5 CFM
Nivel zgomot ventilator Pump: 25 dBA
Fan radiator: 20 - 38.2 dBA
Fan waterblock: 22.8 dBA
Presiune aer 3.2mmH2O
Altele Pump bearing: Ceramic
Conector: 3 pin
Lungime tuburi:
CPU - Radiator: 250mm
CPU - GPU: 250mm
GPU - Radiator: 380mm
Folosit dar in stare de functionare excelenta.
Il vand deoarece am achizitionat un alt PC care are deja racire pe apa.
Pret: 370 Lei
Tel 0769285908
