cezaraxani76
Vesnica problema cu sonda lambda
10 Sep 2017, 20:17
Buna seara domnilor
Se pare ca seatul meu a intrat intr o pasa proasta.
Am facut o noua scanare incercand sa gasesc o solutie la relantiul total instabil-accelereaza singura,si pe modulul engine a aparut o eroare la sonda lambda b1s2.initial a dat sistem too lean,apoi am sters-o ramanad doar sonda b1s2.Nu sa aprins check engine dar miroase a benzina nearsa.postez mai jos log-ul,in speranta ca poate voi primi un sfat de la dumneavoastra.cu respect Cezar Axani
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 FH
Component: SIMOS71 1.6l 2V 9431
Revision: --H01--- Serial number: SEZ7Z0E3022491
Coding: 0000071
Shop #: WSC 10183 428 83821
VCID: 6ADB2423458A324E2A7-803F
1 Fault Found:
16521 - Oxygen (Lambda) Sensor B1 S2
P0137 - 006 - Signal too Low - Intermittent
Freeze Frame:
Temperature: 80.0°C
Resistance: 65.52 kOhm
Voltage: 4.820 V
Bin. Bits: 00000001
Readiness: 0000 1000
Seat Altea reference 1.6 benzina
