LivintLucian
Semnificatii Tablou De Sigurante (FuseCard)
21 Mai 2017, 14:02
Salut !
Mi-am cumparat si eu , nu de mult un Seat Ibiza 1,4 16V din anul 2003.Am o problema in legatura cu sigurantele , mi s-au ars mai multe si as dori sa le schimb.Stiu unde se afla si posed si acel FuseCard , dar ma cam bat putin acele imagini.Daca ar putea careva sa-mi spuna semnificatiile pentru fiecare mi-ar fi de mare ajutor.
Multumesc anticipat ! :D
Cox-Leon
Localitate: Moinesti
Re: Semnificatii Tablou De Sigurante (FuseCard)
21 Mai 2017, 16:10
POST PRELUAT DE PE : SeatCupra
Sper ca am cautat corect si ca datele corespund , daca nu macar sa iti faci o idee.
This is a guide for the fusebox layout in all models from 2002 - 2008 (including Cupra and FR)
F1 - 15A - Spare (up to November 2005), coolant pump (from November 2005)
F2 - 10A - ABS/ESP
F3 - Nil - Spare
F4 - 5A - Stop light, Clutch Switch
F5 - 5A - Engine management control unit (petrol)
F6 - 5A - RH sidelight
F7 - 5A - LH sidelight
F8 - 5A - Heated Mirrors
F9 - 10A - Oxygen Sensor
F10 - 5A - Audio system
F11 - 5A - Spare (up to May 2005), folding mirrors (from May 2005)
F12 - 5A - Headlight leveling
F13 - 5A - Power Steering, engine management, additional heating
F14 - 10A - Additional heater, engine management
F15 - 10A - Automatic gearbox control unit
F16 - 15A - Heated seats
F17 - 5A - Engine Management
F18 - 10A - Instrument cluster, air conditioning, headlight leveling
F19 - 10A - Reversing lights, heated washer jets
F20 - 10A - Washer pump
F21 - 10A - RH main beam
F22 - 10A - LH main beam
F23 - 5A - Number plate light, side light indicator
F24 - 10A - Rear wiper
F25 - 10A - Engine management
F26 - 10A - Stop light switch, ESP steering angle sensor
F27 - 5A - Instrument cluster, ODB-II port
F28 - 10A - On-board power supply unit, glovebox light, luggage compartment light, interior lights
F29 - 5A - Climate control
F30 - 5A - Rain sensor
F31 - 25A - LH front electric window
F32 - 15A - Spare (up to May 2006), cigar lighter (from May 2006)
F33 - 15A - Alarm
F34 - 15A - Engine management
F35 - 20A - Sunroof
F36 - 25A - Heater blower
F37 - 20A - Headlight washer
F38 - 15A - Front/rear foglights
F39 - 15A - Engine management (petrol)
F40 - 30A - Engine managament (diesel)
F41 - 15A - Fuel gauge
F42 - 15A - Engine management
F43 - 15A - RH dip beam
F44 - 25A - LH rear electric window
F45 - 25A - RH front electric window
F46 - 20A - Front wiper
F47 - 20A - Heated rear window
F48 - 15A - Direction indicators
F49 - 15A - Cigar lighter (up to May 2006), spare (from May 2006)
F50 - 15A - Cetral locking
F51 - 20A - Audio, navigation, telephone
F52 - 20A - Horn
F53 - 15A - LH dip beam
F54 - 25A - RH rear electric window
Battery Fuse Panel (upto November 2005)
F1 - 175A - Alternator / Starter
F2 - 110A - Interior
F3 - 50A - Power assisted steering pump
F4 - 40A - Glow plugs (diesel)
F5 - 40A - Radiator fan
F6 - 40A - ABS
F7 - 25A - ABS
F8 - 30A - Radiator Fan
F9 - 10A - Vacant (up to April 2004), ABS (from May 2004)
F10 - 5A - Onboard supply control unit
F11 - 5A - Radiator fan control unit
F12 - Nil - Spare
F13 - 5A - Automatic gearbox control unit
F14 - Nil - Spare
F15 - Nil - Spare
F16 - Nil - Spare
Battery Fuse Panel (from November 2005)
F3 - 40A - Radiator fan
F4 - 40A - ABS
F5 - 50A - Power assisted steering pump
F6 - 50A - Secondary air pump (engines BJX, BKV, BBU and BLZ), Glow plugs (TDI engines)
F7 - 25A - ABS
F8 - 30A - Radiator fan
F9 - 5A - Radiator fan control unit
F10 - 15A - Onboard supply control unit
F11 - 5A - Onboard supply control unit
F12 - 5A - Diesel direct injection system control unit (engine BMT), Automatic gearbox control unit
LivintLucian
21 Mai 2017, 19:51
Super , se potrivesc , mersi mult!
Totuși , îmi poti spune care este siguranța pentru lumina din portbagaj? Se pare ca engleza asta e peste nivelul meu.
Cox-Leon
21 Mai 2017, 21:24
Asta : F28 - 10A - On-board power supply unit, glovebox light, luggage compartment light, interior lights
Daca intradevar este trecut ca "luggage compartment light"
