Tipsie Aurel
nu porneste
18 Ian 2017, 21:16
ibiza 1,4 2003 benzina nu porneste, la testare cu vag-com la engine nu vede ECU la CENT.ELCT au urmatoarele erori
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Control Module Part Number: 6Q1 937 049 C
Component and/or Version: 00 BN-SG. 1S32
Software Coding: 16396
Work Shop Code: WSC 06402
VCID: 3B755D8A29A48A9AB5-5140
Fault Codes have been Erased
3 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Tipsie Aurel
Re: nu porneste
19 Ian 2017, 14:01
la testarea cu vag-com Engine am eroare ,,no response from controller,, am testat si alte functii ABS, airbag etc si totul functioneaza. Care este problema? se pare ca ecu nu raspunde sau nu este alimentat.
Tipsie Aurel
Re: nu porneste
19 Ian 2017, 15:36
Port status: Ok
Interfaces: Ok
Status: ready
K1: Ok
K2: Ok
Can: not ready
Re: nu porneste
19 Ian 2017, 22:05
E corect ce iti da la testarea interfetei. Vezi de ce nu ai alimentare la ECU: sigurante, vreun releu, chiar si contactul electric poate avea ceva.
