Cumatrubody
Nu mai porneste
12 Iun 2016, 11:35
Salutare tuturor,
In ultimul an m-am tot confruntat cu probleme pe care le-am rezolvat mai greu sau mai usor, as putea sa scriu 2-3 pagini lejer :).
Avand in vedere ca este week-end si nu reusesc sa discut cu nici o cunostina mecanic, apelez la voi.
Este vorba de un leon 1.4 benzina 2008
Joi am parcat masina normal fara nici o problema, vineri cand sa ii dau cheie nu pornea. Ok... pompa de benzina e ok nici o eroare pe bord.
Ieri a venit un prieten si am bagat un scan pe ea si au iesit urmatoarele erori:
5 Faults Found:
16804 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 7
Mileage: 55862 km
Time Indication: 0
Date: 2000.01.01
Time: 08:26:32
Freeze Frame:
Bin. Bits: 00000000
Load: 46.9 %
Lambda: 1.0 %
Speed: 101.0 km/h
Temperature: 87.0°C
Absolute Pres.: 530.4 mbar
RPM: 3366 /min
16585 - Injector: Cylinder 1 (N30)
P0201 - 000 - Circuit Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 87
Mileage: 56582 km
Time Indication: 0
Date: 2000.01.01
Time: 19:46:32
Freeze Frame:
Bin. Bits: 00000000
Load: 63.8 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Absolute Pres.: 931.0 mbar
RPM: 243 /min
16586 - Injector: Cylinder 2 (N31)
P0202 - 000 - Circuit Malfunction
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 87
Mileage: 56582 km
Time Indication: 0
Date: 2000.01.01
Time: 19:46:32
Freeze Frame:
Bin. Bits: 00000000
Load: 63.8 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
RPM: 243 /min
16587 - Injector: Cylinder 3 (N32)
P0203 - 000 - Circuit Malfunction
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 87
Mileage: 56582 km
Time Indication: 0
Date: 2000.01.01
Time: 19:46:32
Freeze Frame:
Bin. Bits: 00000000
Load: 63.8 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
RPM: 243 /min
16588 - Injector: Cylinder 4 (N33)
P0204 - 000 - Circuit Malfunction
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 87
Mileage: 56582 km
Time Indication: 0
Date: 2000.01.01
Time: 19:46:32
Freeze Frame:
Bin. Bits: 00000000
Load: 63.8 %
Lambda: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
RPM: 243 /min
Readiness: 0000 0000
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Idei pareri?
Re: Nu mai porneste
14 Iun 2016, 08:12
Ma ierti ca intreb.... Da' cum ar putea porni cu DTC-uri la toate injectoarele?
Ia-le la verificat.
