andleip
Nu trage motorul la turatii peste 2500
27 Apr 2016, 19:56
Buna seara, de ceva vreme daca accelerez peste 2500 turatii "cade masina in bot" nu mai trage..nu conteaza in ce treapta este..dupa ce cade in bot chiar daca schimb treapta nu se mai tureaza deloc..nici in turatii mai mici..daca opresc motorul iar merge normal pana o turez iar. am scos mufa de la debitmetru si masina trage perfect si peste 2500 de ture, am facut si o scanare. banuiesc ca e debitmetrul dar as dori sa fiu sigur. mentionez ca e un Seat Leon BXE 105cp. atasez scanarea, multumesc
Tuesday,26,April,2016,18:06:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ7R017636 License Plate: ADRI
Mileage: 187800km-116693mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R017636 Mileage: 187800km/116693miles
00-Steering Angle Sensor -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW:
Component: R4 1,9L EDC G000SG 9249
Revision: --H02--- Serial number: SEZ7Z0F3547331
Coding: 0050071
Shop #: WSC 21202 136 87566
VCID: 73E539471240F386991-8026
1 Fault Found:
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 187357 km
Time Indication: 0
Date: 2000.00.00
Time: 18:06:25
Freeze Frame:
RPM: 2457 /min
Speed: 113.0 km/h
Load: 74.1 %
Voltage: 14.29 V
Bin. Bits: 00101000
Absolute Pres.: 1999.2 mbar
Absolute Pres.: 2509.2 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06403 785 00200
VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 3561C75F5CB4ADB6775-8060
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004209747
Coding: 81880F2F00041000001D00000000000000017F075C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06403
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 187407 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PSFXBJG
Coding: 0021042
Shop #: WSC 81033 120 08486
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME1100084F
Subsystem 2 - Serial number: 6342MSME10626846
Subsystem 3 - Serial number: 6351HTS6PLLI23Q2
Subsystem 4 - Serial number: 6361HTS6PLLU4NL2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74E73A5B174EF4BE80B-8021
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00581 210 64475
VCID: 306FF64BA3D6889E243-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066148C54
Coding: 3D3F034007000202
VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 187407 km
Time Indication: 0
Date: 2000.00.00
Time: 05:26:22
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000533788127
Coding: 0004272
Shop #: WSC 12336 024 394758
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 44386 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560084F01207C80
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11006001 Serial number: 00000011068606
Coding: 0000176
VCID: 3C77D27B7F9E7CFE88B-8069
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1103
Revision: 11004001 Serial number: 00000000190362
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1103
Revision: 11004001 Serial number: 00000000196621
Coding: 0000144
Vlad.
Re: Nu trage motorul la turatii peste 2500
27 Apr 2016, 20:18
Masina iti intra in Limp-Mode.
Cat despre eroarea aia, am avut fix aceeasi eroare la B7 inainte sa crape turbo de tot. Nu vreau sa te sperii, dar... Oricum, nu e neaparat sa fie turbo gata. Overboost/underboost poate avea multe cauze. Vezi daca turbo iti face presiune suficienta in mers si verifica sa nu ai pierderi de vacuum pe la furtune.
andleip
27 Apr 2016, 20:25
si asta cum fac?unde trebuie sa intru sa vad parametrii din mers?
27 Apr 2016, 21:44
Ia pe cineva care se pricepe. NU o sa poti urmari singur si parametri si pe unde mergi in acelasi timp.
Stiu caz concret de gat rupt dintr-o chestie de genul asta (diagnoza in mers de unul singur).
Vlad.
28 Apr 2016, 00:02
Zice foarte bine Cosmin. Iei pe cineva care se pricepe cu interfata de diagnoza, iesi pe drum, cauti o portiune dreapta de drum, pui in treapta a4a si apesi de la 1500 rpm pana in capat. Daca n-ai unde, poti face si in a3a. Ideea e ca in full boost, trebuie sa fie in stare sa tina presiunea constanta.
Fa asta, salveaza logul si revino, ca sunt si eu curios. Nu te apuca de schimbat piese deocamdata.
andleip
28 Apr 2016, 14:36
Problema e ca sunt in Italia si nu cunosc pe cineva care sa se priceapa..pasii ma intereseaza care trebuie sa ii urmez..am o diagnoza 12.12 neoriginala..banuiec ca intru la select control module-engine-measuring blocks- dupa?as putea sa il pun pe cumnatul meu sa conduca in timp ce fac eu diagnoza. multumesc
andleip
02 Mai 2016, 09:44
am iesit cu ea pe autostrada,,,am tinut`o in 140-160km/h 50 km, nu mai am probleme deocamdata, si`a revenit
