Buna ziua, am facut o scanare masinii si au iesit niste erori..imi poate spune cineva despre ce eroare este vorba? ar trebui sa schimb ceva?multumesc
Friday,15,January,2016,13:11:33:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ7R017636 License Plate: ADRI1
Mileage: 185040km-114978mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R017636 Mileage: 185040km/114978miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW:
Component: R4 1,9L EDC G000SG 9249
Revision: --H02--- Serial number: SEZ7Z0F3547331
Coding: 0050071
Shop #: WSC 21202 136 87566
VCID: 73E539471240F386991-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06403 785 00200
VCID: 3F8DA5776E8867E6AD9-806A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 3561C75F5CB4ADB6775-8060
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004209747
Coding: 81880F2F00041000001D00000000000000017F075C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06403
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PSFXBJG
Coding: 0021042
Shop #: WSC 81033 120 08486
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME1100084F
Subsystem 2 - Serial number: 6342MSME10626846
Subsystem 3 - Serial number: 6351HTS6PLLI23Q2
Subsystem 4 - Serial number: 6361HTS6PLLU4NL2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74E73A5B174EF4BE80B-8021
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00581 210 64475
VCID: 306FF64BA3D6889E243-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066148C54
Coding: 3D3F034007000202
VCID: 2C57E23B8FFEEC7E18B-8079
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 31008001 Serial number: 00000533788127
Coding: 0004272
Shop #: WSC 12336 024 394758
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 44386 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560084F01207C80
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 2
Reset counter: 119
Time Indication: 0
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
1 Fault Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1103
Revision: 11004001 Serial number: 00000000190362
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1103
Revision: 11004001 Serial number: 00000000196621
Coding: 0000144
VCID: 3C77D27B7F9E7CFE88B-8069
