Salut, nu demult am in bord aprins becul ABS, si cateodata se si stinge. La viteza mica, atunci cand apas fransa intra brusc ABS-ul, am chemat pe cineva cu un tester si as vrea un mic ajutor. Va pun mai jos rezultatele, daca se poate sa ma ajutati cu un raspuns la eroare, si cam ce ar trebuii sa cumpar, ma astept la un senzor nou...nu stiu. Va multumesc !!
Sunday,01,March,2015,16:22:31:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ6LZ6R070132 License Plate: ALEX
Mileage: 239190km-148625mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ6R070132 Mileage: 239190km/148625miles
Part No: 045 906 019 BS
Component: 1,4l R3 EDC 0000SG 7359
Coding: 00102
Shop #: WSC 06402
VCID: 67D7A3DC05931526359-49D8
VSSZZZ6LZ6R070132 SEZ7Z0E3070213
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002160
Shop #: WSC 06403 785 00200
VCID: 81031D44DBF74B161BD-5072
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 20
Reset counter: 48
Mileage: 239051 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 0505
Shop #: WSC 00000 000 00000
VCID: 2855E0E0980DDA5EFC3-50E6
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
VCID: 3C7D2CB02C9566FE88B-5072
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
VCID: 79F3F5A4632793D6D3D-5072
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 801 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00135
Shop #: WSC 00000
VCID: 2757E3DCC513D526F59-5072
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: F0E54880B05D529EE43-5072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
VCID: 6FE7CBFC2D63CD667D9-5000
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00016
Shop #: WSC 06402
VCID: 3D7B21B4378F6FF6BF5-4A9C
