Serch
Hello from Spain
18 Dec 2014, 19:20
Hello from Spain.
Where I can find the DIY from this post viewtopic.php?f=187&t=14899
Thx
Re: Hello from Spain
18 Dec 2014, 19:25
Hello and welcome!
Sorry, a DIY is not available. I presumed nobody was interested, so i only resumed most common retrofittings.
What exactly are you trying to do, maybe i can help...
Serch
19 Dec 2014, 00:08
A lot of them:
- Senzor de ploaie / lumina
- Oglinda interioara cu sistem automat anti orbire
- Lumina torpedou
- Lumina suplimentara in portbagaj
- Lumini in zona picioarelor fata / spate
- Sistem spalare faruri
- Senzor nivel lichid de parbriz
- Monitorizare nivel de uzura placute frana
- Conversie halogen / bixenon AFS
- Door warning / exit lights
- RSE (Rear Seat Entertainment)
Do you have them in pdf??
Thx.
19 Dec 2014, 11:12
Ohoho... There's a lot of work involved. And i mean A LOT :)
I don't have them in PDF format, sorry. And i haven't taken pictures either.
I suggest that first of all you must have all the parts. Then get to work. And if you get stuck, ask here. I will do my best to help you.
Good luck!
Serch
23 Ian 2015, 22:37
Hello Cosmin.
I have a problem with the door electric...
I have a Toledo 2005 and my doors are:
door driver: 1T0 959 701 A
door passanger: 1T0 959 702 A
The new, from Altea XL of March 2008:
1T0 959 702 G // 1K0 959 792 M
1T0 959 701 G // 1K0 959 793 M
The connectors are the same but the pinout is different!!!
Can tell me the pinout of the door electric?? Can tell me the wires that I have ti add, change or remove??
The only person that can help me is you.
My english is very bad, but I have a friend romanian; if you are more confortable with your language no problem, my friend can traslate it to spanish.
Thank you!!!
30 Ian 2015, 21:16
The easiest solution is to use the same modules. Otherwise, you need to re-wire. Either you make the wiring from scratch, or use the door wiring of the 2008 XL model.
If you choose to upgrade the front door controllers, you will need to check compatibility with the rear door ones. First generation and 2nd generation is wired via CAN, 3rd gen is wired via LIN. Also first and 2nd generation rear locks are wired directly to convenience module, 3rd are wired to the rear door control module.
Search the web for the convenience diagram and if you don't find it, leave an email adress here.
Serch
30 Ian 2015, 23:41
My mail:
serchserch@msn.com
I hope that you can help me...
How I can know if the news modules are the 2nd o 3rd generation??
Thx, Serch
