salut! sunt noul posesor al unui seat toledo 1.9 tdi 81kw ASV din 2002 varianta de accesorizare cred k e signa
am o lista de erori a vag-comului careia nush cum sa ii dau de cap....ma ajuta cineva...macar sa imi zica ce sa incep sa verific
Thursday,06,November,2014,17:47:57:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Mileage: 81160km-50430mi Repair Order:
Chassis Type: 1M - Seat Toledo (2000 > 2004)
Mileage: 81160km/50430miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001 001 00001
VCID: 32610288AED1A08E527-5000
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00043
Shop #: WSC 06402
VCID: 234FF7CCB12B3906A91-254E
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 17: Instruments Labels: 1M0-920-xx0-17.lbl
Part No: 1M0 920 800 C
Component: S5-KOMBIINSTR. VDO V13
Coding: 04142
Shop #: WSC 01412
VCID: 244DF4D0B4253E3ED0B-5000
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0X0149689
IMMO-IDENTNR: SEZ7Z0X0149689
8 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
01176 - Key
65-10 - Unauthorized - Intermittent
01176 - Key
07-00 - Signal too Low
01314 - Engine Control Module
49-00 - No Communications
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00046
VCID: F0E54880B05D529EE43-5000
3 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 3K Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06402
VCID: 3A712AA826A158CE9A7-49D8
Subsystem 1 - Part No: 1C1959801A
Component: 3K Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 3K Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0004
1 Fault Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
