Salut!
Cum spune si titlul am cateva probleme la seatul meu. Nu am nici o treaba cu partea mecanica a masinii,dar mi-am achizitionat un VCDS versiunea 12.12 si am facut o scanare a masinii deoarece becul "check engine" imi sta pornit de cand am cumparat masina.
Aceasta este scanarea masinii mele:
Sunday,26,October,2014,12:07:06:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 1M - Seat Toledo (2000 > 2004)
Mileage: 163700km/101718miles
Part No: 036 906 034 BD
Component: MARELLI 4LV 3774
Coding: 00031
Shop #: WSC 00000
VCID: 55A167DFAFF48DB6975-4A9C
6 Faults Found:
17582 - Fuel Trim; Bank 1
P1174 - 35-00 - Injection Timing Deviation (Balance Fault)
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 35-10 - Signal too High - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
17598 - Linear O2 Sensor; Reference Voltage
P1190 - 35-10 - Implausible - Intermittent
17586 - Linear O2 Sensor; Pump Current
P1178 - 35-10 - Open Circuit - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00046 615 1234567
VCID: 2B55E12789F0EB46111-5072
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00040
Shop #: WSC 00046
VCID: 23450907B1202306A91-2566
Part No: 6Q0 909 605 A
Component: 1G AIRBAG VW5 0004
Coding: 12615
Shop #: WSC 00046
VCID: 3561C75F0FB4ADB6775-4A3A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 821 A
Component: S5-KOMBIINSTR. VDO V03
Coding: 04106
Shop #: WSC 47694
VCID: 2541171FBF14DD36C75-5072
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0763011
IMMO-IDENTNR: SEZ7Z0Y0763011
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00046
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 76 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
VCID: 8407EA9B94EE443E30B-4A9C
Subsystem 1 - Part No: 1J0959801F
Component: 76 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J0959802G
Component: 76 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 76 Tõrsteuerger. HL0002H
Subsystem 4 - Part No: 1J4959812C
Component: 76 Tõrsteuerger. HR0002r
1 Fault Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
As dori sa imi rezolv toate problemele aratate de vcds deoarece becul din bord imi sta pe creier si nu cred ca este normal sa ai probleme cu masina,sa stii de ele si sa nu le rezolvi.
Va deranjez cu acest post fiindca(cum am spus si mai sus) nu am pic de cunostinte in domeniul mecanicii.
Daca puteti sa ma ajutati cu sfaturi si sa imi spuneti ce trebuie sa schimb as fi tare recunoscator.
Va multumesc anticipat!
