Ce iti apare pe display cand il aprinzi ? In caz ca iti apare "SAFE" nu sAVE, e o procedura:
To enter the code according to the manual :
keys out of the ignition, turn the radio on and leave it saying "safe"
Introduce your code by pressing number keys 1-4
eg, if the code was 1734 you would not press the number 1 button as this is already showing "1" in "1000" press number 2 button seven times, number 3 button 3 times and number 4 button four times.
Confirm the code number by preessing and holding the "PROG" key until it beeps and the display reads "safe"
http://www.seatcupra.net/forums/showpos ... ostcount=2
daca ai nevoie de traducere, te ajut
sper ca e de ajutor,fara vizita la dealer
