20 Mai 2013, 21:01
EGR blocat sau plin de depuneri, clapeta de acceleratie murdara, poate regulatorul de presiune benzina lucreaza prea sus (peste 3 bari), posibil scurgeri in sistemul de recuperare gaze (canistra de carbon), precum si alte cause posibile precum:
Heated Oxygen Sensor (HOS) and ox sens contr behind cat
Potentiometer for EGR –G212 –
Heated Oxygen Sensor (HO2S) ox sens contr before cat –G39-
Fuel pump –G6-
Exhaust Gas Recirculation (EGR) valve
Exhaust gas recirculation valve –N18-
Cylinder 1 injector –N30–
Cylinder 2 injector –N31–
Cylinder 3 injector –N32–
Cylinder 4 injector –N33–
EVAP canister system is leaking
Fuel pressure regulator and retaining pressure
Leak in intake system
Exhaust system before catalytic converter
As miza pe mizerie depusa pe EGR si clapeta, apoi pe sonda lambda.
Cat despre acel tremurat...masoara compresia in cilindri si vezi daca sunt diferente mai mult de 10% intre valori. Bujiile sunt schimbate sau nu sti nimic? Ce cod motor ai?
