Mie mosul mi-a adus un cadou mai nedorit. O eroare pe bord.
Cod: Selectaţi tot
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 FF
Component: SIMOS71 1.6l 2V 7004
Revision: --H01---
Coding: 0000071
Shop #: WSC 06441 785 00200
VCID: 68D5A6795B68FA9
2 Faults Found:
16520 - Oxygen (Lambda) Sensor B1 S2
P0136 - 006 - Malfunction in Circuit - Intermittent
Freeze Frame:
RPM: 1952 /min
Mass Air / Rev.: 92.7 mg/str
Bin. Bits: 00100000
Voltage: 0.340 V
RPM: 1248 /min
Mass Air / Rev.: 81.8 mg/str
Bin. Bits: 00100000
Voltage: 0.400 V
16521 - Oxygen (Lambda) Sensor B1 S2
P0137 - 006 - Signal too Low - Intermittent
Freeze Frame:
Temperature: 64.0°C
Resistance: 65.52 kOhm
Voltage: 5.100 V
Bin. Bits: 00000001
Temperature: -32.0°C
Voltage: 5.100 V
Bin. Bits: 00000000
Readiness: 0010 0001
Stie cineva despre ce este vorba ? A mai intampinat cineva asta ?
Mentionez ca eroarea in unele zile e aprinsa, in unele nu.
