Azi dupa ce am facut o verificare cu VAG Com-ul mi-au aparut urmatoarele erori:
Chassis Type: 1M - Seat Leon/Toledo
VIN: VSSZZZ1MZ2R071252 Mileage: 150210km/93336miles
Part No: 036 906 034 CP
Component: MARELLI 4MV 4376
Coding: 00031
Shop #: WSC 06402
VCID: 62C1DB2CEE54AEE
VSSZZZ1MZ2R071252 SEZ7Z0A1429279
1 Fault Found:
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 31636460AB32456
No fault code found.
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
VCID: 22419B2CAED4EEE
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 04106
Shop #: WSC 00000
VCID: 244D9D34B4C0E0E
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 06402
VCID: F0E52164B0B88CE
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 E
Component: 2U Komfortgerát HLO 0003
Coding: 00067
Shop #: WSC 06402
VCID: 39735C4023428D6
Subsystem 1 - Part No: 1C1959801A
Component: 2U Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 2U Tõrsteuer.BF KLO 0002
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
Va rog daca puteti sa imi spuneti ce inseamna aceste erori, mai ales prima P0420.
Am mai fost la un mecanic si mi-a zis ca e dusa sonda lambda nr.1 inainte de catalizator, am cumparat una universala de la bosch cu 4 fire dar cand am vrut sa o schimb am vazut ca cei de la magazin nu o comandasera bine caci a mea de pe masina era cu 5 fire si am dus-o inapoi pentru ca asa a zis mecanicul ca nu e buna ca imi trebuie cu 5 fire.
As avea nevoie de ajutorul vostru daca v-ati confruntat cu aceste probleme.
As vrea sa stiu totusi daca sonda cu 4 fire este buna sau nu. Imi trebuie neaparat cu 5 fire?
Va multumesc
