samson
Manuale si DIY-uri ALTEA
10 Apr 2012, 10:21
De pe net adunate cateva pdf-uri utile pentru montat si demontat diverse elemente de pe Altea. Chiar daca prezentarile sunt in germana, franceza, spaniola.... imaginile sunt destul de explicite.
- montare tips final - http://www.mediafire.com/view/?a9rbird99qgw0s1
- sita pt. recipient lichid parbriz - http://www.mediafire.com/view/?3d9vpgqtfndcz93
- demontare stopuri - http://www.mediafire.com/view/?eh932p89x73z7dj
- montare lampa plafon centrala spate - http://www.mediafire.com/view/?4wfqanw3wq8bber
- PIN out - http://www.mediafire.com/view/?dtteeydddzs458j
- montare inele bord - http://www.mediafire.com/view/?3tt7lzmy8b3w275
- capace oglinzi - http://www.mediafire.com/view/?krabh91jh0jg2kp
- bancheta culisanta spate - http://www.mediafire.com/view/?awbtfcnyljrnels
- montare element crom hayon - http://www.mediafire.com/view/?dr9gc5s078qmxfy
- demontare proiectoare - http://www.mediafire.com/view/?26xuqdso6xgpg46
- demontare torpedou - http://www.mediafire.com/view/?oph67ipmbql5u5h
- schimbare filtru polen - http://www.mediafire.com/view/?7esdyqahqodx0tq
- montare incalzire oglinzi - http://www.mediafire.com/view/?lxp3jfo1cop70pd
- montare raft portbagaj - http://www.mediafire.com/view/?i1eii9k04gx9040
- demontare tunel - http://www.mediafire.com/view/?1106mpmeahritp6
- montare avertizare apa parbriz - http://www.mediafire.com/view/?ufoadm76tkmze42
- inlocuire pedale model TT - http://www.mediafire.com/view/?1s94a5xxagosxm8
- video AUX - http://www.mediafire.com/view/?mj1xk5csj8r2aje
- montare diuze incalzite - http://www.mediafire.com/view/?kego5b4apmb4uep
- traseu alimentare subwoofer - http://www.mediafire.com/view/?x4h8l2qnrnb1ndc
- traseu alimentare subwoofer(DSG) - http://www.mediafire.com/view/?12l76q2rtw2aq0j
- montare lumina ambientala - http://www.mediafire.com/view/?p4gq16z61bb77du
- confectionare suport lombar - http://www.mediafire.com/view/?tai67516uwnt6il
- montare carlig - http://www.mediafire.com/view/?th2vv6pq8cb0oc3
- metode reparare motor - http://www.mediafire.com/view/?usjd0ldaxeapags
- montare lampa torpedou - http://www.mediafire.com/view/?5mpnzb882z0s814
- DSG-02E - http://www.mediafire.com/view/?2m5of2oc9coa23y
- Installation Kit Allumage des feux Automatique SEAT - http://www.mediafire.com/view/?byiilw7xj93wdn7
- inlocuire maciuca schimbator - http://www.mediafire.com/view/?2d7odooniudtex2
- inlocuire lichid frana - http://www.mediafire.com/view/?5t0s4y04p2h5ft8
- lumini la picioare - http://www.mediafire.com/view/?cuaa5g0qhwq8uyn
- confectionare grila fagure fara "S" - http://www.mediafire.com/view/?vffgu2b9hagg8lu
- E85 - http://www.mediafire.com/view/?675v8hpsgp7mm7y
- service DSG(inlocuire ulei) - http://www.mediafire.com/view/?otx5or3p52bg9wa
- demontare EGR - http://www.mediafire.com/view/?a6a1a01c9xa5tc2
- demontare ceasuri, consola centrala si aeratoare - http://www.mediafire.com/view/?cmpu8shcjbm8c2y
- inlocuire claxon - http://www.mediafire.com/view/?txb5xi3arb2jdap
Sau le puteti vizualiza si descarca, pe toate, de aici http://www.mediafire.com/?mj1xk5csj8r2aje,12l76q2rtw2aq0j,tai67516uwnt6il,3d9vpgqtfndcz93,7esdyqahqodx0tq,dtteeydddzs458j,n3ltzs9z12bibjv,q3jweihcrczn86d,a9rbird99qgw0s1,x4h8l2qnrnb1ndc,i1eii9k04gx9040,4wfqanw3wq8bber,lxp3jfo1cop70pd,kego5b4apmb4uep,dr9gc5s078qmxfy,th2vv6pq8cb0oc3,ufoadm76tkmze42,usjd0ldaxeapags,27wgzlzn4ihedlc,5mpnzb882z0s814,p4gq16z61bb77du,2m5of2oc9coa23y,byiilw7xj93wdn7,1s94a5xxagosxm8,2d7odooniudtex2,5t0s4y04p2h5ft8,3tt7lzmy8b3w275,cuaa5g0qhwq8uyn,vffgu2b9hagg8lu,675v8hpsgp7mm7y,otx5or3p52bg9wa,1106mpmeahritp6,oph67ipmbql5u5h,eh932p89x73z7dj,26xuqdso6xgpg46,a6a1a01c9xa5tc2,cmpu8shcjbm8c2y,txb5xi3arb2jdap,krabh91jh0jg2kp,awbtfcnyljrnels,nd7qo4i60fsk4ao
Spor la treaba
TIBI
Re: Manuale si DIY-uri ALTEA
10 Apr 2012, 11:24
Completez si eu cu schimbat husa schimbator sau/si nuca
viewtopic.php?f=30&t=1956
huse piele schimbator
cezaraxani76
30 Iul 2017, 12:24
Salut domnilor.am reusit sa ..repar cd ul masinii (seat altea 1.6 2006),si m am gandit sa postez aici poate mai ajuta pe cineva. Inainte de demontare scoateti cd ul din cititor-daca este.Avem nevoie de un card sau orice altceva subtire si dur care poatw fii taiat in fasii,de asemenea un torx de 8 si o surubelnita fina.Pentru demontare am taiat un card in fasii max5-6 mm latime.la mine cele patru table care fixeaza radio cd ul sunt 2 jos si 2 laterale.cele de jos sunt aproximativ unde se termina marginea de plastic a display ului.cele laterale aproximativ langa fanta de la cd.cu rabdare introduceti plasticul intre bord si fatza cd ului pana intra aproape complet.trebuie nimerita exact fanta de la tabla altfel nu iese.dupa asta cu ceva de plastic dur sau altceva rotunjit la capat desfaceti usor cd ul pana iese.apoi demontati clema de alimentare si mufa de la radio-are clema.apoi luati cd ul si puneti l pe o masa sau ceva.scoateti tala de deasupra apoi desfaceti cele doua suruburi care fixeaza cd ul de unitate.dupa asta scoateti cu grija contactul panglica de pe cd si gata.acum puteti lucra.pentru a ajunge la lentila laser trebuie demontat capacul ce vine deasupra cd ului. are patru suruburi fine.apoi se demonteaza celalat capac ce fixeaza cd ul pe motor.este aproximativ triunghiular,are un arc care trebuie demontat-este in dreapta.dupa asta luati un betisor de ureche umezit-il un pic in apa,apoi foarte foarte usor curatati lentila cu miscare circulara.fara spirt parfum alcool sau alte chestii de genul pt ca se poate distruge lentila.apa curata si atat.dupa curatare folositi capatul celalalt de betisor -neaparat uscat- pentru a usca lentila laser. Grija mare sa nu ramana praf sau fire de vata pe ea.Cam gata urmeaza montarea in ordine inversa demontarii.Grija sa cuplati panglica la cd.la montarea pe masina puneti cupla de alimentare si antena radio la loc,apoi pozitionati cd ul si impingeti usor pana intra la loc.am facut operatiunea in 20 de minute si sincer am ramas uimit ca citeste cd uri vechi de 3 ani care nu le citea inainte in ruptul capului.in speranta ca am fost de folos va doresc scces.
Seat Altea reference 1.6 benzina
31 Iul 2017, 10:56
Felicitari!
Pacat ca nu ai adaugat si poze . Am fi putut muta ce ai scris (cu mici corectii de exprimare) la sectiunea DIY.
31 Iul 2017, 11:03
E prima data cand aud de spalare cu apa a lentilei de macar 15 ani de cand fac asa ceva. Doar cu alcool izopropilic am curatat, fara sa stric lentilele, plus ca se usca si singura. Cu al doilea capat dau si eu, dar doar pentru lustru...sa zic asa. Sterg eventualele urme lasate la uscare. In kiturile de curatare umede din comert gasesti recipient cu alcool izopropilic.
mumus
Localitate: Brasov / Sacele
31 Iul 2017, 13:31
Eu avem un cd cumparat de vreo 15 ani, are o mica perie pe interior, cand ajunge laserul acolo se curata automat. Asta daca are praf.
Seat toledo nh 1.2 Tsi
31 Iul 2017, 14:42
Daca se fumeaza in masina, cd-ul ala cu perie nu face mai nimic. Asta daca nu pui o picatura de alcool izopropilic pe ea.
mumus
31 Iul 2017, 15:45
La ce viteza are, miramas sa ramana alcoolul pe perie.
01 Aug 2017, 05:44
Ramane, nu are grija. Peria trebuie sa fie umeda doar, ajunge pentru curatare.
