05 Sep 2011, 15:15
am un scan de saptamana trecuta chiar dar nu am nici o eroare la TCS
Friday,26,August,2011,23:19:16:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 6K - Seat Ibiza/Cordoba
Scan: 01 02 03 08 15 17 25 45 56
Mileage: 156380km/97170miles
Address 01: Engine Labels: None
Part No: 038 906 018 FB
Component: 1,9l R4 EDC 0000SG 2170
Coding: 00005
Shop #: WSC 06402
VCID: 5BB1935FE1E5
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
VCID: 75E5E5E76701
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X03.03
VCID: F4E358E3EC7B
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
VCID: ECD34083B44B
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6K0-920-xxx-17.lbl
Part No: 6K0 920 801 F
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00142
Shop #: WSC 00000
VCID: 2B51039FF1C5
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0697972
IMMO-IDENTNR: SEZ7Z0Y0697972
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00403
Shop #: WSC 12345
VCID: 2B51039FF1C5
6 Faults Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
00855 - Connection to CD changer
49-00 - No Communications
00856 - Radio Antenna
01044 - Control Module Incorrectly Coded
35-00 - -
Seat Ibiza 1,9 TDI 110 cp
model 6k2 din 2001
B-46-BXZ
