salut
am si eu o problema
azi dimineata am trecut printr-o balta si dupa vreo 300 de metri s-a aprins EPC-ul, motorul osciland in turatii intre relanti si undeva la 1500rpm, fara nici un control la acceleratie. m-am tarait pana la firma unde am pus laptopul pe ea.
asta e logul
Address 01: Engine
Control Module Part Number: 03E 906 033 P
Component and/or Version: 1,2l/4V SIMOS3 00HS5328
Software Coding: 00061
Work Shop Code: WSC 10155
Additional Info: VSSZZZ6LZ4R072964 SEZ7Z0C2188735
5 Faults Found:
16785 - Can't Decode, CODE File Not Loaded!
P0401 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
16955 - Can't Decode, CODE File Not Loaded!
P0571 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
17950 - Can't Decode, CODE File Not Loaded!
P1542 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
17579 - Can't Decode, CODE File Not Loaded!
P1171 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
16490 - Can't Decode, CODE File Not Loaded!
P0106 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
Readiness: 0000 0000
scanarea a mers fara probleme, s-au putut sterge erorile, si nu mai apar.
aceiasi problema o am de fiecare data cand trec printr-o balta mai maricica.
spune-mi si mie te rog frumos de unde ar putea fi problema
multumesc
