Astazi mi-a facut din nou figura, numai ca de data aceasta siguranta nu mai prezinta nici o fisura, deci pica faza cu siguranta metalica.
Am facut un scan acum si m-am trezit cu mai multe erori, printre care nu se mai regaseste cea cu ABS-ul de prima data.
1.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage X00.8
VCID: 2855E0E0C80DDA5EFC3-50E6
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
2.
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10111
Shop #: WSC 06402
VCID: 6FE7CBFC2D63CD667D9-50E6
2 Faults Found:
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
01288 - Terminal 30; Steering Assist
07-10 - Signal too Low - Intermittent
3.
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 16396
Shop #: WSC 06402
VCID: 3F875BBC3D837DE6AD9-5072
1 Fault Found:
01598 - Drive Battery Voltage
Dupa ce o sterg pe cea de la Auto HVAC, apare din nou, imediat. Asta ce o mai fi ?
Steeering asist vad ca in sfarsit apare la scan....
Iar centrala electrica...drive battery voltage ?! E drept ca inainte sa fac scan-ul am scos pentru 2-3 minute borna + de la baterie. Oare asta sa fie ?
Pareri ?
