catalinutzu
Re: seatul meu
07 Iun 2014, 17:33
Am facut si eu un test cu VCDS si iata rezultatul
Saturday,07,June,2014,16:36:11:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ6LZ9R016009 License Plate: CTL
Mileage: 100150km-62230mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ9R016009 Mileage: 100150km/62230miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 AF HW: 03C 906 024 F
Component: MARELLI 4HV G 2212
Revision: --H05--- Serial number: SEZ5Z0H6241327
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 62C1B2C8BEB1700EE27-5000
1 Fault Found:
28812 - Body Control Module (Central Electric)
U0140 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 0
Reset counter: 16
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 BC HW: 6Q0 907 379 BC
Component: ABS 8.0 front H06 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0002122
VCID: 7F071BBC2D03BDE6ED9-50E6
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC 00000 000 00000
VCID: 2855E0E0980DDA5EFC3-5072
2 Faults Found:
01273 - Fresh Air Blower (V2)
000 - - - Intermittent
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 000B BN-SG. 2S36
Coding: 24716
Shop #: WSC 06402
VCID: 3E7926B83A8974EEA6F-50E6
Part No: 6Q0 909 605 AD
Component: 03 AIRBAG VW5 0010
Coding: 12339
Shop #: WSC 06401
VCID: 79F3F5A4632793D6D3D-5072
2 Faults Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance Too High - Intermittent
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
36-10 - Open Circuit - Intermittent
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 803
Component: KOMBIINSTRUMENT AGD V05
Coding: 00105
Shop #: WSC 00000
VCID: E8D520E0888D9A5EBC3-5000
Part No: 6N0 909 901
Component: 0305 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
VCID: F0E54880B05D529EE43-5072
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER AGD V05
Coding: 00105
Shop #: WSC 00000
VSSZZZ6LZ9R016009 SEZ5Z0H6241327
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10111
Shop #: WSC 06402
VCID: EDDB51F4A76FBF76CF5-5072
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00019
Shop #: WSC 06402
VCID: 3D7B21B4378F6FF6BF5-49D8
doomduke
Re: seatul meu
09 Iun 2014, 13:21
28812 - Body Control Module (Central Electric) duce la erorile:
Eu cred ca releul de alimentare pentru ECU este stricat, prin urmare, toate celelalte adrese (ABS, motor, instrumente, etc), nu sunt in masura sa funcționeze corect. Incerca sa verifici releul Engine Control Module (J271).
De asemenea, verifica si conexiunile bateriei.
Recomand ca verificarea acestui releu sa se faca doar la reprezentanta!
SEAT Ibiza Mk3 (Typ 6L)
Color LS5V Azul Lluvia
Engine specifications
catalinutzu
Re: seatul meu
09 Iun 2014, 17:37
Cred ca stiu de unde se trage eroarea,cand am avut buzerul stricat am dat ceasurile jos si din prostie am pus contactul fara ca acesta sa fie conectat la mufe
De altfel cu masina nu am avut probleme de electrica sau alte probleme,merge ca in prima zi
Ms de raspuns
doomduke
Re: seatul meu
10 Iun 2014, 08:52
Cu placere, tine-o sub observatie.
catalinutzu
Re: seatul meu
10 Iun 2014, 12:28
o sa i mai fac o scanare peste o saptamana sa vedem daca mai da eroarea
Trimis de pe al meu GT-N7100 folosind Tapatalk
nastasedan
Re: seatul meu
08 Iul 2014, 12:54
Ceva tunning Cătă ? :lol:
catalinutzu
Re: seatul meu
08 Iul 2014, 15:14
mai Dane ma gandesc la jante ca ale tale faruri cu lupa discuri spate bara fata/spate de cupra si vedem ce o mai fi
Re: seatul meu
08 Iul 2014, 15:24
Jante ca ale lui eu nu as pune fara arcuri sport, arata cam ciudatel; franele pe ibiza sunt foarte ok avand in vedere puterea ei ; pe mine personal nu m-au dezamagit niciodata, si cateodata mergeam destul de tare ; nu vad rostul..bani aruncati aiurea; farurile cu lupa sunt destul de greu de gasit si scumpe..mie personal nu mi s-a parut ca arata mai bine cu farurile alea cu lupa ; cupra lip-ul, folie pe bara fata, o bara spate de cupra si un tips, volan cu comenzi, grile tip fagure, eleron, stopuri de cupra, astea mi se par niste modificari care ies in evidenta si care chiar merita ; dar te va costa ceva...mai bine o vinzi si cumperi una FR / Cupra :)
p.s : scuze, am citit gresit..mi-e lene sa sterg tot..am inteles ca vrei frane de cupra...bara fata mi se pare mai frumoasa cea de facelift, mai ales cu o folie neagra la numar si un cupra lip de 1M...bara spate la ibiza imi place mult, si eu vroiam una insa cam sare de 1000 lei nevopsita...
catalinutzu
Re: seatul meu
21 Iul 2014, 14:53
In cateva zile urmeaza schimbul de ulei,si anume,LM Sinthoil ,filtre si bujii
catalinutzu
Re: seatul meu
29 Iul 2014, 10:21
Gata ...am facut schimbul de ulei LM Sinthoil High Tech 5w 40,bujii NGK din fabrica a avut Bosh dar am crezut ca are NGK,si filtre MANN
Ce sa zic am fost foarte multumit de LM din aceasta cauza am continuat tot cu el
nastasedan
Re: seatul meu
30 Iul 2014, 12:19
Cat te-a costat uleiul ? 4L ?
catalinutzu
Re: seatul meu
31 Iul 2014, 18:56
am dat 55 de lei per litru si am luat 3l ca mai aveam jumate de litru de la schimbul trecut,dar este al 2 lea schimb si parca sa schimbat total masina,motor f silentios,il auzi doar daca depasesti 4000 de ture
