1.2 TSI/TFSI
1.2 TSI in Golf 7⌕ 1.2 TSI in Golf 7Displacing 1,196 cc, the 1.2 TSI engines all have the same 71mm bore and 75.6mm stroke. They have a cast aluminum alloy block for lightness and die-forged steel crankshaft for strength. This family of four-cylinder turbocharged engines is produced by Skoda Auto at the Mlada Boleslav. All use demand-controlled injectors which eliminate the need for a return fuel system. The single turbocharger offers 1.6 bars of pressure and is equipped with a front-mounted intercooler.
The 1.2 TSI (... - textul complet AICI)
The cheapest TSI engine currently on offer is the 86 hp (63 kW) at 4,800rpm and 160 Nm (118 lb-ft) from 1,500rpm. First offered on the Golf 6 as an alternative for the 1.6 MPI, entering production under the CBZA internal name.
A 90 PS (66 kW) version of the same 8-valve engine engine was launched on the Polo 5 in 2011. It delivers its output 300rpm lower but has the same 160 Nm (118 lb-ft) torque levels.
1.2 TSI engines also offer 105 hp and 175 Nm (129 lb-ft) of torque on select models. These engines have four valves per cylinder and offer improved performance.
Sa reluam:
???!!!These engines have four valves per cylinder and offer improved performance
Noua generatie adica?
Cica asa ar arata noul 1.2 TSI:
