29 Sep 2014, 11:21
Uite si scanarea ta originala, inainte modificare:
VCDS Version: Beta 14.8.1
Data version: 20140905
Saturday,27,September,2014,17:24:01:46441
Chassis Type: NH (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: *****
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZA) Labels: None
Part No SW: 03F 906 070 HB HW: 03F 907 309 AE
Component: SIMOS10.22AH10 5481
Revision: --H10--- Serial number:
Coding: 001100D6200400080000
Shop #: WSC 73430 031 00205
ASAM Dataset: EV_ECM12TFS02103F906070HB 004005
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: E9D39DB908CC0B72EE-80BC
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 614 517 BD HW: 6R0 614 517 BD
Component: EBC 460 ESP H08 0004
Serial number: A00KUO2
Coding: 5129281489B200B98A4714D891A50040480400
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW_SE25.rod
VCID: F6E9C6C54972D48A73-80A3
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6JA 820 045 B HW: 6JA 820 045 B
Component: Man AC H08 0101
Revision: 2015SH08
VCID: B66906C501F2948AB3-80E3
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 P HW: 6R0 937 086
Component: BCM PQ25 M++4 H34 0411
Revision: BD034001 Serial number: 0579 119140805
Coding: 62980B0000130000000800302C0B0CC00E40400F60020000020000004000
Shop #: WSC 73430 790 00205
VCID: C9937D39600CEB72CE-809C
Subsystem 1 - Part No SW: 6JA 919 719 B HW: 6JA 919 719 B
Component: E221__MFL-PR6 H04 0130
Coding: 001000
1 Fault Found:
01700 - Alarm Horn for Anti-Theft System (H8)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 43
Mileage: 1101 km
Time Indication: 0
Date: 2001.14.02
Time: 20:32:45
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0365
Serial number: 003K7R03HFY/
Coding: 88CCC00000000000540000CA000000000065
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253_SE25.rod
VCID: B46D3CCD1F8E869A8D-80E1
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 411 404 14
Component: SideSensor_Df 003 0148
Serial number: 349651A0142312F2AFEL
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 411 404 14
Component: SideSensor_Pf 003 0148
Serial number: 350651A010595D74FCCR
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 411 404 14
Component: SideSensor_Dr 003 0148
Serial number: 351651A01421D494FCDN
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 411 404 14
Component: SideSensor_Pr 003 0148
Serial number: 352651A0142A9B029FBK
Coding: 2D2D2D
Address 17: Instruments (J285) Labels: None
Part No SW: 6JA 920 800 D HW: 6JA 920 800 D
Component: KOMBI H01 0711
Serial number: 00000000000000
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: B87508FD03E662FAA1-80ED
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086
Component: GW-K-CAN TP20 H34 0411
Revision: BD034001
Coding: 322200
VCID: F0E5F0DD2316FABAA9-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H01 0711
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: EAD1E2B50DCA006AE7-80BF
Address 44: Steering Assist (J792) Labels: Redir Fail!
Part No SW: 6R1 909 144 P HW: 6R1 909 144 E
Component: EPS_TRW_ALow 311 3104
Serial number: CE520117
Coding: 0003
ASAM Dataset: EV_SteerAssisUDSTRW 009017
ROD: EV_SteerAssisUDSTRW_SE25.rod
VCID: C48D6C0D4F2E361A3D-8091
Address 56: Radio (J503) Labels: None
Part No SW: 6JA 035 156 HW: 6JA 035 156
Component: Radio H05 0006
Revision: R0000000 Serial number: SEZAZ1P6585009
Coding: 0501020002
VCID: F5EBC1C95C74DF927A-80A0
End-------------------------(Elapsed Time: 01:37)--------------------------
Ultima oară modificat 29 Sep 2014, 12:21 de către
gamer555, modificat 1 dată în total.
Motiv: scos VIN
