  • 3
  • 4
  • 12
Re: Seat Leon 5F - test drive
15 Ian 2013, 17:37
Am facut un pic de munca de negru si le-am sortat cat de cat, pentru FR
Date auto
Numar sasiu VSSZZZ5FZDR007106
Model Leon FR LE
Data fabricatie 17.12.2012
An model 2013
Cod vanzare 5F15P1
Cod motor CKFC
Cod cutie viteze PFL
Tip transmisie 6S
Dotare CP
Culoare plafon 9M
Culoare exterioara / Cod vopsea 9M / S3H
2H5 Driving profile selection and conventional shock absorber
1E0 Without activated charcoal canister
3B4 Child seat anchor for child seat system ISOFIX
2WA Without additional tires
9TA Without additional warning lights
4UP Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
0K0 Without alternative drive module
8ZH Antenna for AM/FM reception, "diversity"
7AA Electronic vehicle immobilization device
QH1 Voice control
9M0 Without auxiliary/parking heater
3H0 Without backrest release for front seats
TS1 4-cylinder diesel engine 2.0 L unit 04L.B
J2D Battery 380 A (68 Ah)
5C0 Without special body measures
K8G Hatchback
9U1 Brake pad wear indicator
1ZE Disc brakes, front (Geomet D)
1KD Disc brakes, rear
1AT Electronic stabilization program (ESP)
4L6 Breakaway interior rear view mirror,automatically dimming
2JD Sports bumpers
KA0 Without camera systems/accident sensors
QK1 Camera and/or distance sensor (driver assistance system)
5D1 Carrier frequency 433.92 MHz-434.42 Mhz
7RE SD card (Europe)
EC4 With CD drive and two SD card slots
6E3 Front center armrest
3C7 3-point seat belt for center rear seat
3G0 Without child seat anchor front (ISOFIX)
QJ3 Chrome package(type 2)
0Y1 Standard climatic zones
0C0 Standard
QR8 Without traffic signs recognition
B0A Component parts set without country-specific design requirement
6FH Exterior mirror housings painted
S0C Introductory volume
8T2 Cruise control system (CCS) electronic
FC0 Without customized installation
4N2 Standard dashboard
2A0 Without delivery equipment
1Y3 Differential lock (XDS) dynamic traction control
4I2 Radio remote controlled central locking operated from inside without safe lock
3LJ Door and side trim panel in foam film, insert in leatherette
0A2 4 doors
QN3 Drawers under front seats
1X0 Front wheel drive
AV1 Driving on the right
EF1 ECO function
UF8 Electric interface for external use
7MJ Emission standard EU5 plus
8Z5 Not hot country
DN4 4-cylinder turbo diesel engine 2.0 l/110 kW (4V) TDI common rail b.e.:TS1/TR1/T0P/T0N/T13/T29/TM4/TD1/TI9
A8H Top sports equipment
0P1 Rear side exhaust tailpipe
7W0 Without extended safety system
6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
2B2 Additional exterior noise suppression
6A0 Without fire extinguisher
1T0 Without first aid kit and warning triangle
0TA Without floor mats
1U8 W/o folding table on front seat backrest
2V5 Fresh air intake system with activated charcoal canister
6K0 without Front Assist/without city automatic emergency braking
8WH Front fog lamp and cornering lamp
6W0 Without license plate carrier front
Q2J Comfort front seats
0AE Front stabilizer
1SA Without additional front underbody guard
1Z0 Initial standard fuel filling
0F5 Fuel system for diesel engine
2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
6Q2 Leather gearshift knob/handle
C02 Operating permit, alteration
8GU Alternator 140 A
5N3 Folding grab handles
6PC Leather hand brake lever handle
FA0 Control of standard production
8IT LED headlamps
8K3 Separate daytime running lights with low beam assistant and "Coming Home" feature
8X1 Headlight washer system
8Q3 Automatic headlight-range adjustment dynamic (self-adjusting while driving)
5ZF Front headrests
7E6 Electric auxiliary air heater
9T1 Heated washer nozzles, front
9AK Climatronic with impact pressure control free of cfc
UG1 Hill hold control
8Y1 Two-tone horn
1EX Special identification plate for EC for M1 passenger vehicle
2G5 Filler neck module 1 without insert
0EN Installation differentiation for transmission MQ 350 vehicle components
U5A Instrument insert, km/h speedometer
6T2 Interior light in footwell front and rear
5SJ Left exterior mirror: convex
4SM Left vanity mirror illuminated with cover and pocket
8G1 High beam assistant
QQ0 Without add. lights (interior lighting)
1PA Standard wheel bolts
3U1 Foldable trunk cover
5A2 Comfort trunk lining
4U5 Luggage pockets on backrest
7P4 Manually adjustable lumbar support in
front seats
0FA Standard manufacturing sequence
9S6 Multi-function display/on-board computer "Colour"
0NB Nameplate set in base trim
7UF Navigation system - Standard
9Z0 Operating voltage 12V
3ZB 3-point seat belts, outer rear with ECE label
0XN Information kit in French and Dutch
5K7 Transport protection film (minimum protection) with additional transport protection measures
7X2 Park distance control, front and rear
UH0 Parking brake
3CA Without partition
VF0 Standard pedal cluster
VL0 Standard pedestrian protection measures
4P0 Rear floor panel module, type 1
I8D Standard radio (Gen1)
8S4 Two reading lights front, two rear
0N1 Standard rear axle
3GA Without cargo area
8TB Rear fog light
3T2 Three rear headrests
UK1 Standard rear seat release
3NZ Rear seat bench unsplit, backrest split folding
0BA Without rear stabilizer
8M1 Rear window wiper and washer system with intermittent control
KK1 Refrigerant R134a
1W0 Without refrigerator/glove compartment cooling system
ER1 Regional code " ECE " for radio
EM1 Rest Assist (drowsiness detection)
3QT 3-point seat belts with tensioner and height adjustment, front
5RQ Right exterior mirror: convex
4TD Right vanity mirror illuminated
3Y0 Without roll-up sun screen
3FA Without roof insert (standard roof)
3S0 Without roof rails/roof load rack
2UC Sports version
7M3 Scuff plates in door apertures
3L3 Manual height adjustment for front seats
9P5 Seat belt reminder, optical and acoustic electric contact
N0W Fabric seat covering
4A3 Seat heater for front seats separately controlled
QI6 Service indicator 30,000 km or 2 year ( variable )
QG1 Service interval prolongation
G02 Front shock absorption
1JC Rear shock absorption for sports design
4X3 Side air bag front with curtain air bag
4KF Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
7Y4 Lane departure warning
9JA Non-smoking package
7B0 Without socket
1G8 Breakdown set
9VD Speaker (active)
E0A No special edition
2KW Labels/plates in German, French, and Dutch
7L6 Start/stop system with regenerative braking
1N3 Speed-related variable steering assist (Servotronic)
L0L Left-hand drive vehicle
2PF Leather trimmed multi-function sports steering wheel
EA0 Without subsequent warranty
8SK Taillight assemblies with diodes (LED)
9ZX Mobile phone preparation
7K9 Flat tire indicator
V0A Tires w/o specification of tire brand
HM4 Tires 225/40 R18 92Y xl
1S3 Tool kit
1D0 Without trailer hitch
G0K 6-speed manual transmission
7N0 Without tray on roof liner
2P1 Plastic trunk sill protection
QV0 W/o TV reception/digital radio reception
B02 Type approval Belgium
7LF Vehicle class differentiation -5F0-
F0A No special purpose vehicle, standard equipment
8W1 Washer fluid level indicator
L15 Suspension range 15 installation control only, no requirement forecast
0YC Weight range 3 installation control only, no requirement forecast
1NL Covers for alloy wheels
0B1 Wheelbase
C0T Alloy wheels 7.5J x 18
4R4 Power windows with comfort operation and circuit breaker
4GF Windshield in heat-insulating glass
8N6 Windshield wiper intermittent control with light/rain sensor
mususk266
15 Ian 2013, 19:49
daca noul toledo e sedan, ce se va intampla cu exeo? oare sa fie gen: exeo=octavia si toledo=rapid?
ravemstr
Mediatorul
16 Ian 2013, 11:48
Toledo este fix o Skoda Rapid. Masinile sunt 99% identice.
De ce noul Leon nu are torpedoul captusit? :( Se aduna cateva chestii care chiar conteaza...
OEM+ Leon FR, 1.4TSI
TIBI
16 Ian 2013, 13:12
mususk266 scrie:
Nu se intampla nimic,sunt clase diferite
Exeo=vw passat,audi a4,adica din clasa medie
octavia din ce stiu e in clasa compactelor
huse piele schimbator
mususk266
16 Ian 2013, 15:06
octavia compacta? pai atunci rapide ce e? clasa mica?
tytelu1
Localitate: Marghita - Bihor
16 Ian 2013, 17:14
Octavia e sedan compact, poate poate cu acest model nou, sa intre mai sus cu o clasa, clasa medie.
Rapid si Toledo sunt una si aceeassi masina din clasa comacta, sedan compact.
Seat Exeo 1.8 TSI 120 HP
andrei.27kim
16 Ian 2013, 20:10
mususk266 scrie:
Octavia este o strutocamila :tongue . Este platforma de G5, leon, doar ca cehii au tras de tabla aia de nu sa mai putut si au dus-o la limita superioara a clasei compacte. Se simte la interior unde nu ai mai mult loc ca intr-un golf dar la exterior para sa intre peste Passat in clasa lui.
TIBI
16 Ian 2013, 22:49
mususk266 scrie:
Priveste altfel...skoda superb in ce clasa se situeaza daca octavia zici ca e precum exeo? :tongue
Octavia e o compacta, ela limita clasei compacte mai exact.
Toledo si rapid sunt un fel de nise...ceva intre,de ''umplutura''.
Toledo nu mai e un leon cu portbagaj(scuzati-mi exprimarea mai din topor :oops: )
17 Ian 2013, 01:41
Perfect de acord cu TIBI: octavia, leon, rapid, toledo...toate sunt clasa compacta :hi
tibetan_afurisit
Localitate: Braila
05 Feb 2013, 13:33
Cosmin scrie:
Noi, ca si posesori (sau fosti posesori) de Seat avem oricum o parere subiectiva si in general respingem orice caracteristica care e diferita fata de ce avem pe masinile personale. Dupa cum se vede, am accentuat "in general" :)
E normal sa fie asa.Sunt tocmai caracteristicile ce te-au determinat sa iei aceasta marca si nu alta.
Mie personal nu-mi place noul Leon.Are atitea unghiuri ascutite si muchii incit mi-e frica sa ma apropii de el sa nu ma tai :yh
Cred ca-i sta bine intr-o reclama la Gillette. :D
1P-ul ramine pentru mine supremul in design.O parere subiectiva desigur.
Citeva trasaturi le regaseam in noul Astra,fapt care ma facea sa intorc capul dupa ea ori de cite ori o vad pe strada.Ma indragostisem de masina asta si in sufletul meu imi doream sa apara noul Leon sa ...rupa gura tirgului.A aparut. Acum dupa ce am vazut noul Leon nu mai sunt indragostit de Astra.Acum iubesc Astra !
In schimb imi plac muchiile si unghiurile ascutite la noul Toledo. Mai taie,atenueaza, din aspectul mare,greoi si ii da o linie fluida.
Ca posesor de Cordoba...ajuns la o anumita virsta :yh as merge pe mina noului Toledo.
E o masina care arata bine si-n care arati bine.Indiferent cum esti imbracat cind esti sau cind cobori din ea.Fie ca esti la costum,fie ca esti imbracat sportiv.
Ca o concluzie dat fiind ca inima-mi bate pentru Seat ,as alege noul Toledo dintre toate masinile din gama.
Astra cred ca ramine...o iubire de-o vara. :)
Ca o concluzie la...concluzie ,dincolo de design,caracteristici si motorizari,Seat imi place ca a unit niste oameni de nota 10+ pe forumul asta.
Doamneee...cit am mai scris.M-a luat valul ! :D
Seat Cordoba 1,4/100CP
Psihologu' de serviciu.
forbs
05 Feb 2013, 15:51
I-au sters clar din personalitate.
Cu tot subiectivismul asumat, linia noua de design o arunca in marea masa a compactelor.
Pana si ideograma, de la un simbol ce desena in linii curbe, fluente, o masina, au ajuns la un dreptunghi ce simbolizeaza ce! un far???
Interiorul, cel hate-it or love-it, era orientat catre driver, masina era construita pentru el, de la face lift i-au taiat personalitatea.
Normal ca au fost nevoiti sa includa gadget-uri ca nu mai sunt SF, dar oare Da Silva ce zice?
My humble oppinion...
radu4iasi
09 Feb 2013, 02:25
Nu inteleg de ce sunteti surprinsi
New Ibiza
New Leon
Personal prefer Leonul 1P
Cel nou nu e urat, dar nu mi l-as cumpara :D
20 Feb 2013, 11:52
Sambata asta vom mai face un test drive cu Leon 5F echiparea FR, motorul diesel 2.0 150 CP.
Asteptam intrebarile, curiozitatile voastre si ce anume vreti sa pozam.
De data asta o sa avem la dispozitie o ora, asa ca poate reusim sa facem macar un filmulet.
Varianta de 184 CP va fi disponibila in Belgia, cel mai devreme 15/07/2013.
Titix88
Localitate: Cluj
20 Feb 2013, 12:27
tot nu-mi vine sa cred ca ala este noul LEON!!!! :cry :cry :cry:
Prin faptul ca arata monoton au scos in evidenta cat de frumos si unic este Seat Leon 1P. Cred ca o sa fie singura masina la care pretul ar trebui sa creasca dupa ce se lanseaza un model nou :yah
@Roger.. ia vezi cat de bine se descurca la un light crash test ( GLUMAAAAA) cu toate astea chiar nu pot suporta noul leon.. :alien:
Nissan Primera Acenta 1.6i 109 cp 2007
Seat Leon 2.0 TDI 140 cp 2007
Andrei
Admin / PR
23 Feb 2013, 14:24
Hai sa imi spun si eu parerea despre noul Leon!
Aseara am avut ocazia sa merg cu el, un motoras de 1.6 TDI 105CP destul de cuplat pe treaba lui....frumos foc, nu ma asteptam! E o masina unica si merita cu adevarat banutii. Pe mine unul m-a impresionat atat calitate cat si pretul de pornire de la care va porni. Este o masina frumoasa, eleganta, agresiva si toata lumea intoarce capul dupa ea!
O sa revin cu poze.
ex SEAT Leon 1M 1.8T
ex SEAT Leon 5F FL
ex SEAT Ibiza 6L
  • 3
  • 4
  • 12
