Si niste date despre masinile pe benzina :
SEAT León TFSI, 5 doors.
ENGINE:
4-cylinder in line, transversally installed. Distribution: two overhead camshafts, 16 valves. Displacement: 2000 cc. Bore x stroke: 85 x 88 mm. Compression ratio: 11:1. Maximum output: 260 bhp @ 8500 rpm. Maximum torque: 250 nm @ 7000 rpm. Engine management: Magneti Marelli. Lubrication: wet sump.
TRANSMISSION:
Front-wheel-drive. Gearbox: Hewland 6-speed, sequential shift. Clutch: twin-plate. Differential: mechanical limited slip differential.
CHASSIS:
Front suspension: McPherson strut, coil springs, gas-filled dampers, anti-roll bar. Rear suspension: multilink axle, coil springs, gas-filled dampers, anti-roll bar. Steering: power assisted rack and pinion.
BRAKES:
Not-assisted dual circuit system. Front brakes: 4-piston calipers, 332 mm steel ventilated discs. Rear brakes: 2-piston calipers, 280 mm steel discs.
DIMENSIONS:
Length: 4330 mm, width: 1849 mm, wheelbase 2600 mm, minimum weight: 1170 kg including the driver.
