  • 20
  • 21
  • 22
  • 23
  • 24
  • 26
BOGY26
Re: DJ-1-5EAT
25 Iun 2013, 10:14
L-am sunat acum pe Marian LPH si sper sa mearga varianta lui, un "restart al softului" piesei..astept sa ma sune sa imi zica cum sa fac cu VAG-com...prea dureros ptr. un senzor :mrgreen:
BOGY26
Re: DJ-1-5EAT
25 Iun 2013, 15:54
Asa se "reseteaza" Intake Manifold Runner, ptr. cei care se pricep la VAG-com :?:
Prerequisites:
Ignition ON
Engine OFF
System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 142
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF for at least 60 seconds.
Multumesc :!:
BOGY26
Re: DJ-1-5EAT
25 Iun 2013, 21:02
Marian, multumesc frumos ptr. sprijinul acordat, dar se pare ca trebuie sa ajung pe la acest senzor, sa verific cablajele, firele, contactele si daca nu este nici de acolo o sa trebuiasca schimbat..pe tester la momentul "Wait until Field 4 shows "ADP. O.K." imi da "ADP. ERROR" la cifra 30 si nu trece mai departe si culmea este ca ramane eroarea salvata chiar daca o sterg...aveti cumva idee pe unde este situat acest senzor :?: :idea:
Multumesc :!:
P.S mai jos este LOG-ul:
Tuesday,25,June,2013,20:23:47:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ8R004965 Mileage: 49220km/30583miles
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: SEZ7Z0G3774307
Coding: 0303000318070160
Shop #: WSC 04941 785 00200
VCID: 306B14F3DAB3
1 Fault Found:
012690 - Intake Manifold Runner Control: Basic Setting Aborted - Mech. Stop Closed
P3192 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Mileage: 49226 km
Time Indication: 0
Date: 2000.00.00
Time: 20:21:14
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 39.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73E1DBFF6B25
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 C
Component: ClimatronicPQ35 011 0602
Shop #: WSC 00000 000 00000
VCID: 2C530083F69B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004946658
Coding: A18E8F2F00041000431D000000000A0000017F075C4000
VCID: 6CD3C083361B
Part No: 1P0 955 119 B
Component: Wischer 280507 022 0601
Coding: 00056208
Shop #: WSC 04941
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PLGW5A.
Coding: 0021042
Shop #: WSC 10180 468 84702
VCID: 2F69178FC78D
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 810D0137A199
Part No: XXXXXXXXXXX
Component: E0221 005 0060
Part No: 1P0 920 825 B
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 10180 599 84702
VCID: 2D550D87CD81
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K075218036
Coding: E9807F060002020202
VCID: 306B14F3DAB3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
VCID: 2D550D87CD81
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000032678412
Coding: 0000176
VCID: 3B7133DF03F5
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 356525E725D1
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 989800005283CC7F0006800260084FA6307C80
VCID: 83010B3FBB85
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1129
Revision: 31008001 Serial number: 00000551078330
Coding: 0000176
VCID: 3C7330C306FB
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0010402
Shop #: WSC 06402 785 00200
VCID: 2B51039FF395
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000001647374
Coding: 0000144
VCID: 3B7133DF03F5
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000001648282
Coding: 0000144
VCID: 3C7330C306FB
LIFEPHORM
Re: DJ-1-5EAT
26 Iun 2013, 13:31
Incearca sa reiei basic settings inca odata. Daca piesa este defecta, trebuie inlocuita, nu prea te mai ajuta nimic. Pentru asta trebuie data jos galeria de admisie si rampa de injectoare si recalibrat senzorul motorului, dupa ce schimbi piesa, desigur.
Daca ai un pic de "mana-de-lucru" poti face si tu inlocuirea, am vazut acum ceva timp ca oamenii pe-afara prin SUA mai ales, si-au inlocuit singuri piesele.
http://forums.vwvortex.com/showthread.p ... Flap-motor)-with-pics - uite un link cu DIY, insa nu mai merg pozele, o sa fie nevoie sa faci rost din ETKA de o schema...
Ciudat la numarul asta de kilometri sa se strice piesele astea, eu nu am schimbat nimic la a mea in aproape dublu decat ai tu. Am vazut la altii probleme si cu PCV-ul, si cu HPFP. Foarte ciudat!
BOGY26
Re: DJ-1-5EAT
26 Iun 2013, 15:24
Salut Marian,
m-am documentat si eu pe alte forumuri si am vazut ca este o problema comuna la 2.0 TFSI, la multi, aceasta piesa s-a schimbat in perioada garantiei, cu km mai putini ca ai mei..baftosi...am vazut cateva poze cum s-ar schimba piesa numai ca este de munca si nu pricep asa bine la mecanica...o sa comand piesa la producatorul VDO(din ce am inteles tot ei echipeaza masinile VAG)-->500 lei...
Azi m-am interesat si am pe masina piesa cu litera B la sfarsitul codului..de atunci a mai aparut C, D si ultima revizie find E din 2010 "incoa", deci clar o sa schimb senzorul asta...de recalibrat banuiesc ca se recalibreaza tot cu VCDS-ul cum am incercat prima data, nu? dar sa speram ca va depasi ADP ERROR si va fi ADP OK :mrgreen:
Cu aceasta ocazie voi schimba si uleiul(desi are aprox. 8000 km) + toate filtrele.
Am mai vazut ca urmeaza sa "cada" PCV-ul, pompa de inalte si ar mai fi cateva piese legate tot de PCV...sper sa NU cada toate sau sa cada vara asta :shock:
Oricum multumesc ptr. sfaturi si ajutor, in caz de ceva te mai sun :mrgreen: :wink:
BOGY26
Re: DJ-1-5EAT
27 Iun 2013, 13:24
LIFEPHORM scrie:
Cine ma poate ajuta si pe mine cu aceasta poza :?: :idea:
Eu am ceva dar este un motor de pe un A3 si nu stiu daca este aceeasi pozitionare...
Multumesc :!:
BOGY26
Re: DJ-1-5EAT
28 Iun 2013, 12:18
Azi s-au comandat urmatoarele:
- senzor, Intake Manifold Runner Control, producator VDO
- 6L ulei Motul 300v PR 5W30
- 1L lichid frana ATE DOT4 Super Blue Racing
- toate filtrele pe MANN, mai putin cel de benzina care l-am comandat pe UFI
Saptamana viitoare ajung toate si tot atunci le voi schimba...
Drive safetly :!: :drive :mrgreen:
BOGY26
Re: DJ-1-5EAT
05 Iul 2013, 14:27
BOGY26 scrie:
S-a inlocuit tot ce este mai sus...dar ca de obicei cand mergi la doctor iti mai descopera inca o boala..am ceva probleme la capatul de bara dreapta fata, asa ca l-am comandat si pe asta pe Lemforder si luni sau marti il voi schimba...in rest..drumuri bune :drive
LIFEPHORM
Re: DJ-1-5EAT
05 Iul 2013, 17:46
Pune si preturi!
BOGY26
Re: DJ-1-5EAT
05 Iul 2013, 19:26
- senzor Intake Manifold Runner Control, producator VDO - 500 lei
- 6L ulei Motul 300v PR 5W30 - 360 lei
- 1L lichid frana ATE DOT4 Super Blue Racing - 50 lei
- toate filtrele pe MANN, mai putin cel de benzina care l-am comandat pe UFI - 205 lei
- manopera - 160 lei
- cap bara dreapra fata Lemforder - 100 lei
:cheers :drive
BOGY26
Re: DJ-1-5EAT
06 Iul 2013, 12:20
LIFEPHORM scrie:
Nu s-a dat jos nici galeria de admisie si nici rampa de injectoare :mrgreen: Momentan nu am reclaibrat senzorul fiindca nu este baiatul cu laptopul acasa..dar merge foarte ok masina..si-a revenit si consumul :D
boditza
Re: DJ-1-5EAT
07 Iul 2013, 20:55
maine o facem.. acu ajunsai :)
BOGY26
Re: DJ-1-5EAT
07 Iul 2013, 22:06
Maine seara, dupa ora 20 o facem, cand ies eu de la munci :mrgreen:
BOGY26
Re: DJ-1-5EAT
09 Iul 2013, 11:48
boditza scrie:
Multumesc frumos Bogdan :cheers
Maine sa schimb capul de bara dreapta fata si am cam scapat de belele....deocamdata :mrgreen:
TIBI
Re: DJ-1-5EAT
09 Iul 2013, 17:00
Pana ti se mai descopera inc-o maladie :tongue
Mor pe chestia asta.La mecanici e precum la stomatologi
huse piele schimbator
  • 20
  • 21
  • 22
  • 23
  • 24
  • 26
