razvanEL
Localitate: Comanesti. Bacau
Re: inele bord seat toledo
28 Oct 2015, 17:26
Am incercat si nici asa nu merge ....dimineata vine cu testerul
razvanEL
29 Oct 2015, 12:44
am facut diagnoza si cam asta mi.a dat
cod 1:
18058 P1650 data bus sporadic:
powertrain:
missing mesage from instrument cluster ECU
cod 2:
17978 P1570 Engine control module disabled
daca stie cineva ce inseamna astea sa ma ajute
Bogdan.A
Localitate: Brasov, Ro
29 Oct 2015, 15:18
salut, conform site-ului Ross Tech:
1. Prima eroare, conexiunea cu ceasurile din ce inteleg. Esti sigur ca mufele sunt bagate bine si corect? de asemenea vezi sa nu fie urme de oxid pe mufe.
18058/P1650/005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
Possible Solutions
Check Fuse(s)
Check Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285)
Check/Replace Instrument Cluster (J285)
Check Measuring Value Blocks (MVB)
2. A doua eroare. Este o problema cu cheia care nu este recunoscuta de ceasuri. Sau poate fi bateria care nu este foarte incarcata.
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
Engine starting but stalling immediately
Possible Causes
Key(s) not matched
Instrument Cluster not matched
Engine Control Unit (ECU) not matched
Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes
In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related.
May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module.
If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, on rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
Astea sunt erorile explicate dupa codul de eroare. Poate ne ajuta Dany, cu o explicatie mai pe larg
________
Seat Toledo 1.6 16v 105 cp, True Love :D
29 Oct 2015, 16:45
Eu am zis ca are lipituri reci la mufele bordului, doar acolo este singurul loc in care s-a umblat la masina. Era evidenta o lipsa a comunicarii bordului cu motorul sau a bordului cu cheia. Altceva nu am ce sa zic. Nu sunt in tara, revin abia peste 3 saptamani. Daca nu rezolvi pana atunci, ma pot deplasa pana la tine. Sau, ca alternativa, daca poti duce masina la Onesti, iti pot da un numar de telefon al unui prieten si esti rezolvat sigur.
razvanEL
29 Oct 2015, 17:02
Da cred ca ai dreptate dani ,am pus bateria pe un redresor ca era moarta am mai desfacut iar ceasurile am scos mufele le.am bagat inapoi si o sa vad cand pun iar bateria sa vad ce zice...e normal sa se aprinda masina cu cheia daca sa zicem are vreo lipitura rece?
razvanEL
29 Oct 2015, 17:04
Si dani daca o duc pe platforma pana la onesti imi ia vreo 5,6 mil ,sper sa rezolv pana vi in tara daca nu te contactez
razvanEL
29 Oct 2015, 20:58
Da am pus bateria incarcata si la fel...am tractat.o la un mecanic cu gandul sa o las acolo sa se ocupe de ea,cand am ajuns la el i.am mai dat o cheie si surpriza a pornit masina acum merge normal pff cati nervi degeaba
29 Oct 2015, 21:23
Este posedata... :diabloanifire: :yh
razvanEL
29 Oct 2015, 21:39
Mylux scrie:
Asa am zs si eu :yh.
29 Oct 2015, 22:24
Pana la urma este bine ca s-a rezolvat problema. :drive
razvanEL
29 Oct 2015, 22:38
da normal,sunt bucuros ca ma duc cu masina la servici maine,oricum multumesc pentru sfaturi,aveam de gand sa scot calculatorul sa il trimit la service sa,mi anuleze imobilizatorul
29 Oct 2015, 23:03
Bine ca a pornit. Nu mai desface bordul iar, poate iar o patesti.
razvanEL
30 Oct 2015, 06:26
Gata imi ajunge cu desfacutul :D
