06 Iul 2010, 14:43
Salutare.Vreau sa va spun ca am rezolvat problema.Am cumparat motorul exact dupa referintele care le-am postat mai sus,am desfacut usa am schimbat motorul ,am sters dtc-urile si gata problema rezolvata.Totul merge ok!Asta e ultimul scan realizat:
VCDS Version: Release 908.0
Data version: 20090911
Sunday,04,July,2010,15:45:56:13314
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R005371 Mileage: 127520km/79237miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LL HW: 03G 906 021 LL
Component: R4 2,0L EDC G000SG 9850
Revision: --H02--- Serial number: SEZ7Z0F3502384
Coding: 0050072
Shop #: WSC 00011 781 93875
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 06402 785 00200
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 008 0303
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004117475
Coding: 81880F2F00041000001D00000000000000017F075C
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06402
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R3 AIRBAG VW8 027 2521
Revision: 09027000 Serial number: 003A1PA2FZBQ
Coding: 0021043
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002042
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No: 1P0 920 823 F
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 09034 843 13691
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106502810C
Coding: 3D3F034007000202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000026969121
Coding: 0000176
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560084F86307C80
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06402
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11006001 Serial number: 00000050768516
Coding: 0000176
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0040424
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1105
Revision: 11005001 Serial number: 00000000052818
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1105
Revision: 11005001 Serial number: 00000000020788
Coding: 0000144
Subiect inchis.Adios
Leon 2.0 TDI,stylance 178cp
