zalexxx
Localitate: Radauti
Re: Portbagajul nu se mai deschide
01 Iun 2014, 13:51
salut!
la mine problema nu exista pana de curand..
Acum exista intermitent! adica sunt zile cand nu merge deloc.. zile cand merg 17 deschideri din 20...
Am sters modulele fara cod de eroare.. ca umpleam prea tare postul. Idei cu privire la portbagajul meu (apar 2 probleme relationate.)
vcds zice:
Saturday,31,May,2014,17:30:34:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ5PZ5R053*** License Plate: GTI 31 MAI 2014
Mileage: 182590km-113456mi Repair Order:
Chassis Type: 5P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 7D
VIN: VSSZZZ5PZ5R053*** Mileage: 182590km/113456miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001170614
Coding: 810A5A1700041000003200000000000000
Shop #: WSC 00000 000 00000
VCID: 387FCE6B4BA650DE6C3-806D
Subsystem 1 - Part No: 5P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
2 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
02390 - Control / Regulation for Ambience Lighting (E400)
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0012042
Shop #: WSC 06402 785 00200
VCID: 3169F34FA8DC81962BD-8064
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000048
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 99C000BC090005054C4F863000
Shop #: WSC 16779 000 1048576
VCID: 7BF511673A10BBC6C11-802E
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 7 - Component: NGS n.mounted
2 Faults Found:
00893 - Switch for Trunk Handle (E234)
007 - Short to Ground - Intermittent
00950 - Central Locking Motor - tailgate (V53); UNLOCK
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E5760F5-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
012 - Electrical Fault in Circuit - Intermittent
Maria Alina
Re: Portbagajul nu se mai deschide decat fortat
28 Noi 2021, 19:42
Buna,
Am de curand Seat ATECA 2018..si tehnologia se pare ca m.a doborat...
Am deschis intr.una din zile portbagajul ...nu s.a mai inchis si l.am inchis manual...prin fortare cum spune in manual...
Ideea e ca se deschide foarte putin sau deloc.
Tre sa ii resetez memoria si sa ii reinregistrez alta deschidere?Am incercat si asta...deschis fortat cat vreau sa se deachida el sg si tinut apasat mai mult de 3 sec pe butonul de la portbagaj cu iconul ...dar nu face nimic...daca apas butonul ala sa se inchida sg..nu merge...decat fortat...
Cum sa rezolv?
Maria Alina
28 Noi 2021, 19:43
Buna,
Cum sa rezolv?
01 Dec 2021, 11:49
Te-ar ajuta în prima faza o diagnoza.. sa vezi ce anume nu funcționează
