21 Aug 2009, 17:17
Imi cer scuze ca postez tot eu asa repede,dar am urmatoarele:
Friday,21,August,2009,17:05:57:21461
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 1P0 907 115 C
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0303000318070160
Work Shop Code: WSC 06441
4 Faults Found:
000291 - Throttle Position Sensor (G69): Signal too High
P0123 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 32996 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
008482 - Accelerator Position Sensor (G79): Signal too Low
P2122 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 32996 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 11.938 V
001688 - Sensor Reference Voltage C: Too Low
P0698 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 32996 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 11.938 V
005445 - Throttle Valve Controller: Malfunction
P1545 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 32996 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 31.0°C
Voltage: 12.065 V
Readiness: 0010 0101
Ieri am schimbat filtrul de benzina.
Va rog mult ajutati-ma. Multumesc.
Si ce masina...si ce sofer...
C U P R A
