rap_florinn
Localitate: ploiesti
Re: Problema inchidere centralizata
21 Aug 2020, 21:52
Uite Dany , am rezolvat restul .
Seat Leon 1.6 16v BCB an 2003
21 Aug 2020, 22:00
Ai 4 geamuri electrice? Daca postai testul ca fisier text, vedeam mai multe informatii. Salveaza un scan ca text in Notepad, e cel mai simplu.
rap_florinn
21 Aug 2020, 22:06
Am doar 2 geamuri electrice .
Vineri,14,August,2020,21:32:33:00005
Tip caroserie: 1M (1M - Seat Leon (2000 > 2005))
Adrese de scanat: 01 02 03 08 15 17 19 22 35 36 37 46 56
Numar VIN: VSSZZZ1MZ2R103346 rulaj: 243330km
Adresa 01: Motor Eticheta: ROJ\036-906-034-AZD.clb
Numar VAG: 036 906 034 DS
Component: MARELLI 4MV 4466
Codare: 00031
Atelier: WSC 30011
VCID: 66C28E040267C87610-4B64
VSSZZZ1MZ2R103346 SEZ7Z0B1571918
Nu a gasit coduri.
Gata de functie: 0000 0000
Adresa 03: ABS frâne Eticheta: ROJ\1C0-907-37x-ABS.lbl
Numar VAG: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Codare: 0001025
Atelier: WSC 00001 001 00001
VCID: 31682D58AB295FCE35-515A
Nu a gasit coduri.
Adresa 15: Airbaguri Eticheta: ROJ\6Q0-909-605-VW5.clb
Numar VAG: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Codare: 12620
Atelier: WSC 06441
VCID: 224AD214AECFF456BC-513C
Nu a gasit coduri.
Adresa 17: Instrumente bord Eticheta: ROJ\1M0-920-xx2-17.clb
Numar VAG: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V03
Codare: 04002
Atelier: WSC 00000
VCID: 2446D40CB4DBFA66CE-513C
Nu a gasit coduri.
Adresa 19: Poarta CAN Eticheta: ROJ\6N0-909-901-19.clb
Numar VAG: 6N0 909 901
Codare: 00006
Atelier: WSC 06402
VCID: 70EEE85C30A316C67A-515A
Nu a gasit coduri.
Adresa 46: Confort Eticheta: ROJ\1C0-959-799.clb
Numar VAG: 1C0 959 799 E
Component: 2U Komfortgerát HLO 0003
Codare: 00258
Atelier: WSC 06402
VCID: 397815782359978E8D-4B18
Subsistem 1 - Numar VAG: 1C1959801A
Component: 2U Tõrsteuer.FS KLO 0004
Subsistem 2 - Numar VAG: 1C1959802A
Component: 2U Tõrsteuer.BF KLO 0004
Subsistem 3 - Numar VAG: Steuerger
Component: t HL antwortet nicht
Subsistem 4 - Numar VAG: Steuerger
Component: t HR antwortet nicht
3 coduri de defecte:
01334 - Modul comandã uºa: dreapta spate -J389-
49-00 - Nu este comunicare
01333 - Modul comandã uºa: stânga spate -J388-
01030 - Contact cheie ºofer: încuiat
29-00 - scurt la masã
Sfârsit--------------------(Timp scurs: 03:01, udsna)----------------------
21 Aug 2020, 22:11
Pai de aia ai erorile, ca modulul stie ca ar fi 4. Schimba codarea cu 00067.
rap_florinn
21 Aug 2020, 22:13
O sa incerc maine treaba asta , ciudat este ca nu am umblat pana acum sa codez la inchidere .
Mersi frumos ,te tin la curent .
PS
Si mai este o chestie nu se stinge plafoniera cand inchid usa nici cand o deschid .
21 Aug 2020, 22:21
00258 e coding pentru deschidere selectiva, adica deschide doar usa soferului la prima apasare pe remote, la masini cu 4 geamuri electrice. 00259 ar fi ca sa deschizi toate usile in acelasi timp. La 4 usi/2 geamuri electrice e 00066 pentru deschidere selectiva si 00067 pentru toate usile in acelasi timp.
Chestia cu plafoniera e de studiat putin ca sa vezi care switch e de vina, sau chiar modulul.
Cel mai simplu e cu decuplarea pe rand o usilor, din mufele de pe stalpi, cu contactul pus.
Alta intrebare: sta si vreo lampa de pe usi aprinsa mereu, la fel ca plafoniera?
rap_florinn
21 Aug 2020, 22:23
Da, la mine asa a fost de cand am cumparat masina prima data de deschide la mine si pe urma restul.
21 Aug 2020, 22:33
"Alta intrebare: sta si vreo lampa de pe usi aprinsa mereu, la fel ca plafoniera?"
rap_florinn
21 Aug 2020, 22:37
Nu sta.
21 Aug 2020, 22:46
Atunci nu sunt switchurile de pe usile din fata de vina. Ori una din usile spate, ori modulul de inchidere sau lampa sunt de vina. Incearca cu alta lampa mai intai, imprumuta una, ca doar nu iese greu.
rap_florinn
22 Aug 2020, 10:46
Am codat inchiderea centralizata asa cum ai zis tu si erorile s-au sters .
Cu plafoniera nu am rezolvat inca .
22 Aug 2020, 14:12
Ar trebui sa gasesti destul de usor si cauza problemei cu plafoniera.
rap_florinn
29 Aug 2020, 15:33
Ca sa numai deschid alt topic continui aici .
Ieri am facut ITP-ul la masina si am ramas surprins ca nu imi ieseau gazele , pana acum nu am avut probleme cu ea .Noroc ca am un prieten la itp si au iesit cu brio .
El mi-a zis ca sa nu fie de la benzina (am pus 99 de la Petrom pana sa ma duc la itp).
Bujiile au in jur de 45000km o fi de la ele ?
Clapeta , EGR,senzor MAP au fost curatate in primavara .Prima sonda a fost schimbata la 200de mii .
Din ce mi-a explicat el trebuia sa am o valoare de 0.21 si eu aveam intre 0.24-0.43.
30 Aug 2020, 20:48
A doua sonda,adica cea dupa catalizator,trebuie sa fie si ea in parametrii optimi de functionare,ea este responsabila cu reglarea noxelor evacuate...,altfel slabe sanse sa iasa noxele daca sonda lambda 2 nu este ok sau nu lucreaza in parametrii optimi,chiar daca prima sonda ai inlocuit-o si functioneaza ok tot nu te ajuta sa-ti iasa noxele bune pentru a putea trece itp-ul la noxe.
rap_florinn
31 Aug 2020, 10:37
Cum pot sa o verific sa vad daca lucreaza in parametri normali?
