Salut si bine ai venit !
Comenzile vocale cum functioneaza?
incercand sa dau o comanda si sa o scuz ca nu ma intelege
)xtcr1st1 scrie:Ceva in genul asta s-a intamplat si la mine, numai ca zgomotul era permanent si se intensifica odata cu viteza.2. Se aude un zgomot tip fasait de curea la pornirea la rece - in service nu s-a reprodus. Parca este mai accentuat in partea din dreapta(dpdv al soferului) a capotei.
. Astfel poate o sa insist in a cauta o bara fata de FR/Cupra
Address 01: Engine (03L 906 023 LH)
22:03:54
251 Particle filter; difference pressure-DIP_PF 0.00 hPa
253 Particle filter; field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD 00000000
254 Particle filter; field regeneration request status-STATE_RGN_PF 0
255 Particle filter; fuel consumption since last regeneration-FCO_SUM_RGN 13.43 l
256 Particle filter; kilometers since last regeneration-DIST_RGN 135.6 km
257 Particle filter; offset for differential press.-DIP_PF_AD[0] -2.99 hPa
258 Particle filter; oil ash volume-MASS_ASH_PF 50.9275373 g
259 Particle filter; oil ash volume-MASS_ASH_PF 50.9275373 g
260 Particle filter; soot mass calculated-MASS_SOOT_SIM_PF 14.12 g
261 Particle filter; soot mass measured-MASS_SOOT_PHY_PF 4.01 g
262 Particle filter; time since last regeneration-T_WOUT_RGN 36116.90 s
263 Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST 70.00 g1 Fault Found:
7462 - EGR Valve (N18)
P0403 00 [032] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 183432 km
Date: 2015.12.08
Time: 19:27:15
Readiness: 0000 0000
