Salut am si eu o intrebare mai dificila de fel
, adica eu sunt mai dificil de fel
Am un Seat Ibiza 6L si am o mica nelamurire in legatura cu MUFA OBD II a masinii, din cate am vazut mufa are urmatorii pini ( 4,5,6,7,14 si 16 ) din cate am citit eu pe wikipedia si sper ca totusi informatia era corecta
, pinii 4,5 sunt pentru impamantare, pinul 6 si 14 sunt pentru protocolul CAN iar pinul 7 este pt KWP si pinul 16 pt Baterie.
Acuma problema mea e urmatoare am o interfatza VCDS care nu e originala
si cand intru in program ea comunica cu masina doar prin intermediul KWP si nu prin CAN, cand dau scanare mie imi apar urmatoarele probleme :
Thursday,15,December,2011,15:31:28:63170
VCDS Version: Release 908.0
Data version: 20090830
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ7R145164 Mileage: 25410km/15789miles
Part No: 03E 906 023 D
Component: SIMOS91 1.2l 4V 9510
Revision: --H04--- Serial number: SEZ5Z0G0231575
Coding: 0000071
Shop #: WSC 06402 785 00200
No fault code found.
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage X00.8
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
30-00 - Open or Short to Plus-------------------------------------------------------------------------------
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 000A BN-SG. 2S36
Coding: 16396
Shop #: WSC 06402
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation-------------------------------------------------------------------------------
Part No: 6N0 909 901
Component: 02QT GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
80-10 - Single-Wire Operation - Intermittent-------------------------------------------------------------------------------
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00066
( aici am modificat eu de la 00018, probabil de aici eroarea asta ) Shop #: WSC 06402
Part No: Steuerger
Component: t Fahr. antwortet nicht
Part No: Steuerger
Component: t Beif. antwortet nicht
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
Ce vreau sa intreb:
- pe ce protocol este normal sa vorbeasca intefatza cu masina CAN sau KWP, si cumva la mine vorbeste pe KWP pentru ca interfatza mea este China made ??
- daca poate cineva sa imi explice ce inseamna aceste erori si cum pot fi remediate, ca sa stiu ce sa le zic la service
Va multumesc anticipat
