15 Dec 2011, 11:51
Salut Cosmin,
Acum cateva zile (seara, frig, foarte foarte umed afara, ceata groasa) am lasat masina cu avariile puse vreo 10-15 minute cat am luat un plic de la posta. Cand m-am intors, am pus cheia in contact, am pornit motorul, dar nu s-au mai aprins luminile in bord, butoanele de pe volan nu mai mergeau, imi palpaia in bord martorul de bec ars, si mi-a dat si in MFD un mesaj pe care spre rusinea mea nu l-am retinut. Am oprit motorul de 2 ori, l-am repornit, la fel. Apoi am oprit iar motorul, am scos cheia, am deschis usa, am inchis usa, am pornit - totul era din nou ok. De atunci nu mi s-a mai intamplat asa ceva.
Am atasat si logul mai jos, care arata ca dupa razboi.
Intrebarea mea este urmatoarea: cand ma duc la service cu logul asta, ce sa le zic? Ce s-a intamplat?
Wednesday,14,December,2011,19:01:22:10074
VCDS Version: Beta 11.2.0
Data version: 20110207
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62
72
VIN: VSSZZZ1PZBR029558
02-Auto Trans -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: None
Part No SW: 03L 906 018 FK HW: 03L 906 018 FJ
Component: R4 2,0L EDC H22 7899
Revision: 42H22--- Serial number:
Coding: 001D0012042400080000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM20TDI01103L906018FK 003004
ROD: EV_ECM20TDI01103L906018FK.rod
VCID: 78FBECD3F8F
2 Faults Found:
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - No Signal/Communication
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 15591 km
Date: 2013.14.07
Time: 18:34:34
4714 - Steering Column Control Module: No Communications
U0212 00 [032] - Open or Short to Plus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 15591 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2211
Revision: 05151112 Serial number: 00001002220065
Coding: 0000020
Shop #: WSC 06402 785 00200
VCID: 183BCC53D8F
1 Fault Found:
18275 - Powertrain Data Bus: Missing Message from Steering Wheel (J527)
P1867 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 40
Mileage: 15591 km
Time Indication: 0
Date: 2013.14.07
Time: 18:34:37
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B401209240003881002E990210042350800
Shop #: WSC 04941 000 00000
VCID: 76E7E2EBF2B
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 Q HW: 5P0 907 044 Q
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SE35.rod
VCID: 3E773ACB9AB
2 Faults Found:
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [008] - - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 H HW: 5K0 937 087 H
Component: BCM PQ35 H 011 0035
Revision: BE011001
Coding: 46180A3E902508C042080080950089C442559CA8727D8560008040000040
VCID: 3A7F36DB863
Subsystem 1 - Part No: 1P0 955 119 C
Component: Wischer 21091 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A
Component: REGENLICHTSEN H04 0003
Coding: 02542E
7 Faults Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 13.85 V
ON
ON
OFF
OFF
ON
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 5P0 919 475 C HW: 5P0 919 475 A
Component: PARKHILFE 8K H07 0005
Revision: -------- Serial number: 89041024708742
Coding: 100101
VCID: 3B7133DF899
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Time Indication: 0
Date: 2013.14.07
Time: 18:34:39
Freeze Frame:
Temperature: 7.0°C
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 M HW: 5N0 959 655 M
Component: J234__A0C VW10 HI 1916
Revision: 21014000 Serial number: 003GGP808PCR
Coding: 0012355
VCID: 47995F2FC51
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100924301307
Coding: 1892140002
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SE35.rod
VCID: 7EF7FACBDAB
MFL:
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B
Component: E221__MFL-TAP H02 0102
Coding: E30000
1 Fault Found:
332564 - Databus: Missing Message
U1121 00 [008] - No Signal/Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 0 km
Date: 2000.01.01
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 853 C HW: 1P0 920 853 C
Component: KOMBI H06 0420
Serial number: 00000000000000
Coding: 110F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2F69178F4D1
3 Faults Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Date: 2013.14.07
Time: 18:34:38
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Date: 2013.14.07
Time: 18:34:38
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Date: 2013.14.07
Time: 18:34:39
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 300810F2001085
Coding: EDA17F0640021200000202
VCID: EDD54D8707D
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0420
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE35.rod
VCID: EADF469B363
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668665352
Coding: 010000
VCID: 2759FFAF651
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 5P0 035 191 D HW: 5P0 035 191 D
Component: RNS315 H05 0010
Serial number: SEZAZ2K9107651
Coding: 040004010402000000000000
ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
ROD: EV_RNS315SeatEUV1UDS_SE35.rod
VCID: 2C5300837C7
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0311
Revision: 12101005 Serial number: 0001220844
Coding: 0010B0
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_SE35.rod
VCID: 7CF3F0C3CC7
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388__TSG-HL 006 1401
Serial number: 00000005254212
Coding: 000090
2 Faults Found:
68103 - Function Restricted due to Missing Message(s)
U1111 00 [008] - Short to Ground
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 65 3001
Revision: 00H17000
VCID: 316D11F75B5
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0311
Revision: 14101005 Serial number: 0001360287
Coding: 0010B0
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_SE35.rod
VCID: 79FDE9D7C35
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389__TSG-HR 006 1401
Serial number: 00000005233299
Coding: 000090
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 2556933
VCID: 346318E3A47
Subsystem 1 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul l 0004
Coding: 00000039
Subsystem 2 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul r 0004
Coding: 00000039
2 Faults Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Time Indication: 0
Date: 2013.14.07
Time: 18:34:38
Freeze Frame:
Voltage: 13.77 V
Speed: 0.0 km/h
ABS 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 15591 km
Time Indication: 0
Date: 2013.14.07
Time: 18:34:38
Freeze Frame:
Voltage: 13.77 V
Speed: 0.0 km/h
ABS 1
Address 62: Door, Rear Left
Cannot be reached
Multumesc,
