  • 8
  • 9
  • 10
Olaru.Alexandru
Localitate: Bacau
Re: My first car, My Toledo :)
27 Ian 2018, 17:00
Azi facem un pic de progres. Dupa ce am lasat masina in garaj cateva zile fara sa mai ies cu ea la plimbare si ce am mai umblat azi la ea, am ramas cu urmatoarele:
Chassis Type: 1M - Seat Leon/Toledo
VIN: VSSZZZ1MZ2B003638 Mileage: 218930km/136036miles
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0420SG 3357
Coding: 00002
Shop #: WSC 00046
VSSZZZ1MZ2B003638 SEZ7Z0A1200224
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 00046 615 1234567
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 01
Coding: 12620
Shop #: WSC 00046
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 822 D
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05122
Shop #: WSC 31414
Address 19: CAN Gateway Labels: 6N0-909-901.lbl
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00046
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 93 Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00046
Part No: 1C0959801B
Component: 3K Tõrsteuer.FS KLO 0001
Part No: 1C0959802C
Component: 3K Tõrsteuer.BF KLO 0002
Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0002
Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0002
1 Fault Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Rezolvari
Senzorul de temperatura exterioara si cel de temperatura a antigelului ori aveau umezeala si de la stat in garaj s-a rezolvat. Ori le-au placut caldurica:)) (rezolvat pentru moment)
Am curatat bornele la beterie si punctele de contact de la cabluri.
Verificat mufa de airbag de la pasager, strans pini si pus un zip ca sa fie strans mufa. (rezolvat eroarea)
De facut:(
Am pus un senzor nou la pedala de frana dar tot am aceeasi eroare la apasarea pedalei . Iar senzorul vechi l-am verificat cu multimetru si comuta. Stopurile tot nu se aprind.
Am scos mufa de la senzorul G201 si dat cu un pic de spray de frane si pus la loc, dar degeaba:( (ramane de schimbat senzorul)
Si mai ramane si acel fir de Data Bus
Sanatate, si un weekend placut.
Toledo 1M 2002/ASV/1,9 TDI/110 CP
28 Ian 2018, 11:46
Tot ceva cu switchul de la pedala ai probleme. Firul e direct de la el la lampile din spate. Daca nu rezolvi cu lampile de frana, nici eroarea de senzor de presiune nu va dispare. Asa scrie si la wiki.
Olaru.Alexandru
Localitate: Bacau
28 Ian 2018, 21:15
Ok. Am sa verific daca primesc semnal la lampi cand apas. Sau daca iese ceva de la switch. Multumesc. Sper sa fie senzorul ca ar fi cel mai rapid de rezolvat. O seara buna maestre si multumesc, sanatate.
Olaru.Alexandru
Localitate: Bacau
07 Feb 2018, 20:51
Buna seara,
Azi am cumparat swich ul de la pedala de frana, de la HELLA, si l-am schimbat, am observat ca cel vechi mergea, dar daca apasam pana la "fund", tija nu isi revenea. Si cand ma uitam pe blocul de masura la ABS, in momentul apasari si cand aparea acea eroare, swich ul nu mai comuta, pana isi revenea el...Am sa il desfac pe cel vechi in weekend sa vad ce s-a intamplat in el, si sper ca cel nou sa nu aiba probleme pe viitor. Multumesc mult Dl. Dan pentru sfat si indrumare . Halatul pentru rezolvare 40 de lei:D
Cat despre acel scurt pe CAN bus, a disparut, am incercat sa deschid fiecare usa, sa apas pe fiecare tub de trecere dintre portiera si interior, si sa scanez la fiecare interventie sa depistez daca mai apare si sa-mi dau seama care este vinovatul, momentan se ascunde, dar intr-o zi cu mai multa caldura, dau portierele jos, si verific continuitatea la fiecare fir de la calculatorul de pe usa spre conexiunile din interior.
VIN: VSSZZZ1MZ2B003638 Mileage: 219110km/136148miles
Coding: 00002
Shop #: WSC 00046
Readiness: N/A
Coding: 0019458
Coding: 00044
Shop #: WSC 06402
Coding: 12620
Shop #: WSC 00046
Coding: 05122
Shop #: WSC 31414
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Coding: 00006
Shop #: WSC 00046
Coding: 00259
Shop #: WSC 00046
Part No: 1C0959801B
Part No: 1C0959802C
Part No: 1C0959811A
Part No: 1C0959812A
Senzorul de temperatura am sa il schimb, scapa antigel pe langa acea siguranta, si cred ca umezeste si conexiune.
O seara buna, multa sanatate
08 Feb 2018, 08:12
Nu are treaba, de la scurgere iti dadea "short to ground". E senzorul defect, deci schimba-l odata cu garnitura respectiva.
Olaru.Alexandru
Localitate: Bacau
08 Feb 2018, 15:33
Am dat comanda pentru el. Si sambata fac miscarea. A venit ploaia si au dat inundatiile in masina. Pe covorasul din dreapta fata gasesc apa. Este cumva de la clapete/servo uri de la ac? Mentionez ca atunci cand dau pe incalzit, zona de mijloc de la consola e cald si cele laterale mijloc da aer rece:(
08 Feb 2018, 18:10
Nu au treaba clapetele. Ori de la usa, ori pe la filtrul de aer daca nu are plasticurile puse bine, sau pe sub carcasa filtrului...Grila de la stergatoare e fixata bine in sina parbrizului?
Olaru.Alexandru
Localitate: Bacau
08 Feb 2018, 19:15
Am schimbat recent filtrul. Posibil ca nu l am pus bine. Sper sa fie asta problema. Multumesc maestre pentru tot.
Nu e de la usi. Picura langa tunel pe covor. Am pus mana ca sa gasesc sursa dar n am simtit nimic ud:( am sa dau si torpedoul jos. Poate observ asa mai bine.
Btw planuiesc sa dau la vara toata instalatia de sub bord de la AC si sa vad unde sunt buretii de la conexiuni dintre tuburi duse( burete uscat la pornirea AC ului in grilele de vent). O revizie mica vreau sa ii fac. Intrebarea este: cam cat de greu si daca trebuie ceva special pentru desfacut sau e suficient o surubelnita, ciocan si o bomba:))
Sanatate sa ne vedem cu bine
08 Feb 2018, 23:07
E destul de munca. Scule obisnuite. Trebuie scos freonul inainte de a incepe.
Olaru.Alexandru
Localitate: Bacau
09 Feb 2018, 07:06
Ok. Multumesc. Dar tot nu ma dau batut:)
Olaru.Alexandru
Localitate: Bacau
06 Mar 2018, 22:27
Zilele acestea am participat la un curs. Si am invatat un lucru, sa vizualizam ce ne dorim cu adevarat, si asa cum fac atletii, vizualizarea mintala a pasilor spre ce vrem sa realizam.
Si sa incepem cu ce imi doresc
Si primul pas a fost sa fac rost de:
Clusterul de a3 8l trebuie sa vina saptamana aceasta
Si urmeaza sub indrumarea mentorilor:)
O resoftare pentru clusterul de b5.5
Un schimb de leduri. Folie de polarizare. Si pe plan indepartat un schimb de display. Acesta e pe duca.
Si nu in ultimul rand codarea cheilor. Si montarea.
Facem pasi marumti spre vara.
Ca atunci se anunta alta treaba mai grea:))
O seara placuta
Olaru.Alexandru
Localitate: Bacau
08 Mar 2018, 21:03
Buna seara. Am bifat un pas mic in seara aceasta
O seara buna si spor la km.
Olaru.Alexandru
Localitate: Bacau
14 Mar 2018, 16:14
Buna ziua. Inca un pas facut.
Dar am dat de o problema. Nu gasesc un dump pentru cluster sa il pot adapta pe masina. Am incercat mai multe de Vw golf sau bora dar nimic compatibil. Ma poate ajuta cineva
Seria ceasurilor de passat este 3B0 920 949 A v07
Multumesc.
14 Mar 2018, 16:16
De ce nu suni la cel pe care ti l-am recomandat cu cheile?
Olaru.Alexandru
Localitate: Bacau
14 Mar 2018, 21:37
dany19940 scrie:
Asa am sa fac.
Multumesc mult maestre. Sper sa termin cu capitolul asta. Am pierdut deja 3 zile:))
  • 8
  • 9
  • 10
