Salutare tuturor,
In vara acestui an am achizitionat un seat leon 1p refferance din 2006 motor 1.6 bse cu 126.000Km. Dupa aproximativ o luna de la cumparare dupa ce am crezut ca am rezolvat tot ce era de facut la el (revizie, distributie, schimbat becuri, stergatoare si tot tacamul) a inceput distractia.
In bord se aprind in mod aleator martorii de servo (galben), esp si presiune pneuri. Uneori raman aprinsi la punerea contactului si se sting dupa cateva sute de metri apoi iar se aprin, iar se sting si tot asa. Sunt zile in care nu se aprind deloc. Uneori stau aprinsi martotii de esp si
presiune cauciucuri iar cel de servo se aprinde si se stinge la intervale aleatorii.
In momentul in care sunt aprinsi cei trei martori o scanare facuta cu vcds-ul arata in felul urmator :
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ6R086701 License Plate:
Mileage: 126920km-78864mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ1PZ6R086701 Mileage: 126920km/78864miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 FF
Component: SIMOS71 1.6l 2V 9435
Revision: --H01--- Serial number: SEZ7Z0F3458206
Coding: 0000071
Shop #: WSC 80385 120 96127
VCID: 68DF5E2B5B86005E3C3-803D
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0002689
Shop #: WSC 06441 785 00200
VCID: 71E9334F685CC1966BD-8024
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Shop #: WSC 00000 000 00000
VCID: 3561C75F5CB4ADB6775-8060
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003957181
Coding: 008C0F2F00041000001D00000000000000007B075C
VCID: 2A5BE423850AF24EEA7-807F
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R3 AIRBAG VW8 027 2521
Revision: 09027000 Serial number: 003A1P5W0XE.
Coding: 0021043
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Serial number: 6332MSME0E360B5B
Subsystem 2 - Serial number: 6342MSME0E35495F
Subsystem 3 - Serial number: 6351HTS6TLLA88G2
Subsystem 4 - Serial number: 6361HTS6TLLAGLT2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 634 0070
Coding: 0000002
VCID: 75E1075F1C34EDB6B75-8020
Part No: 1P0 920 804 B
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 10164 599 58504
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106307820C
Coding: 3D0F0340070202
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2395
Coding: 0000176
VCID: 3663C05341B2A6AE7EF-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3365F94752C0B386591-8066
1 Fault Found:
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 18C8003C09080000484B090004CC
Shop #: WSC 40385 188 04712
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000176
VCID: 377DCD5746B85FA6659-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 152
Component: Radio BNO 0035
Coding: 0020400
VCID: E2CBCC033DBAEA0E627-80B7
iar cand martotul de servo este stins iar cei de esp si presiune pneuri sunt aprinsi scanare arata asa:
Coding: 0000071
Revision: 00H13001
Coding: 0002689
1 Fault Found:
000 - -
Coding: 00056272
Shop #: WSC 06441
Coding: 0021043
Coding: 0000002
Coding: 0002101
Coding: 0000176
Component: KSG 0401
Coding: 0000176
Coding: 0020400
de observat ca eroare de pe steering asist dispare pur si simplu.
senzorul g85 l-am inlocuit, am facut readaptarea senzorului de mai multe ori, am inlocuit bateria si am facut geometria rotilor.
In measuring blocs in momentul in care martorii sunt aprinsi valoarea senzorului g85 nu se mai modifica (ramana ultimav valoare citita).
Astept parerile si sfaturile voastre,
multumesc
