23 Sep 2021, 21:32
am si eu problema pe pornire, poate imi puteti confirma sau infirma ca sunt ceasurile de vina.
am fost plecat o luna de acasa, cand m-am intors nu mai porneste. porneste si se opreste dupa o secunda,
bateria are 12.2V, sigurantele sunt bune toate, ceasurile de bord nu nefunctioneaza, nu se aprinde niciun bec pe ceasuri, nimic. in rest se aprind, pe radio, clima etc.
banuiesc la acest moment ca ceasurile sunt moarte.
rezultatul pe diagnoza
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Part No: 06A 906 033 HE
Component: SIMOS71 1.6l 2V 1037
Revision: --H04--- Serial number: SEX7Z0H13180OR
Coding: 0004071
Shop #: WSC 04941 785 00200
3 Faults Found:
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
P0030 - 009 - Open or Short to Ground
Freeze Frame:
Bin. Bits: 00000100
Resistance: 16.38 kOhm
Voltage: 1.840 V
Load: 4.7 %
16897 - Incorrect Immobilizer Key
P0513 - 008 - Implausible Signal
Freeze Frame:
Voltage: 10.51 V
RPM: 1504 /min
Bin. Bits: 00000100
Lambda: -100.0 %
Voltage: 11.73 V
RPM: 0 /min
Bin. Bits: 00000001
Lambda: -100.0 %
28827 - No Communication with Instrument Cluster
U0155 - 009 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00110000
Absolute Pres.: 3.6 bar
RPM: 0 /min
Bin. Bits: 00110000
Absolute Pres.: 3.8 bar
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
1 Fault Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 K
Component: Climatic PQ35 012 0505
Shop #: WSC 00000 000 00000
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005469223
Coding: B18C1F2F00041000431D00000000000000117F072D400008000000000000
Shop #: WSC 18434 020 32896
Part No: 1P0 955 119 B
Component: Wischer 040208 022 0601
Coding: 00056208
Shop #: WSC 18434
2 Faults Found:
02390 - Control / Regulation for Ambience Lighting (E400)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 136804 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 250
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 10.55 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A01 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP1MGADQ
Coding: 0012337
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 250
Mileage: 0 km
Time Indication: 1
Veh. life cycle counter: 0
Part No SW: 1K0 953 549 BM HW: 1K0 953 549 BM
Component: J0527 752 0100
Coding: 0000002
No fault code found.
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0192
Revision: H16 Serial number: 2500K0812501BF
Coding: E9801F060002020202
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 250
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 250
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 12
Reset counter: 250
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 F HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1129
Revision: 32008001 Serial number: 00000144179216
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.065 H08 1901
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80C000CC7F008505484B012004CC
Shop #: WSC 08224 211 56823
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 F HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1129
Revision: 32008001 Serial number: 00000652179028
Coding: 0000048
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0020414
