radu4iasi
Eroare Check Engine 16520 si 16521
26 Dec 2012, 00:00
Craciun fericit tuturor pe aceasta cale!
Mie mosul mi-a adus un cadou mai nedorit. O eroare pe bord.
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 FF
   Component: SIMOS71 1.6l 2V     7004
   Revision: --H01---
   Coding: 0000071
   Shop #: WSC 06441 785 00200
   VCID: 68D5A6795B68FA9
2 Faults Found:
16520 - Oxygen (Lambda) Sensor B1 S2
            P0136 - 006 - Malfunction in Circuit - Intermittent
             Freeze Frame:
                    RPM: 1952 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Bin. Bits: 00100000
                    Voltage: 0.340 V
                    RPM: 1248 /min
                    Mass Air / Rev.: 81.8 mg/str
                    Bin. Bits: 00100000
                    Voltage: 0.400 V
16521 - Oxygen (Lambda) Sensor B1 S2
            P0137 - 006 - Signal too Low - Intermittent
             Freeze Frame:
                    Temperature: 64.0°C
                    Resistance: 65.52 kOhm
                    Voltage: 5.100 V
                    Bin. Bits: 00000001
                    Temperature: -32.0°C
                    Voltage: 5.100 V
                    Bin. Bits: 00000000
Readiness: 0010 0001
Stie cineva despre ce este vorba ? A mai intampinat cineva asta ?
Mentionez ca eroarea in unele zile e aprinsa, in unele nu.
cristi_mky
Inginer
Re: Eroare Check Engine 16520 si 16521
20 Ian 2013, 15:10
HONDA
YAMAHA
VW
SEAT
BUGGY
