pornire dimineata 1.6 aus
Scris: 16 Mar 2017, 15:12
Buna ziua, am o problema la un seat toledo 2001 motor 1.6 aus dimineata la prima pornire se opreste motorul dupa 2 secunde , o pornesc iar porneste si merge fara probleme toata ziua . Am facut o scare cu vag si a dat urmatoare erori :
7 Faults Found:
17582 - Fuel Trim; Bank 1
P1174 - 35-10 - Injection Timing Deviation (Balance Fault) - Intermittent
16804 - Catalyst System; Bank 1
P0420 - 35-10 - Efficiency Below Threshold - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-00 - Electrical Malfunction
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 35-10 - Short to Ground - Intermittent
17589 - Linear O2 Sensor; Reference Voltage
P1181 - 35-10 - Open Circuit - Intermittent
17586 - Linear O2 Sensor; Pump Current
P1178 - 35-10 - Open Circuit - Intermittent
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
Readiness: 0000 0000
7 Faults Found:
