lucian226
Masina plina de erori
13 Ian 2019, 09:56
buna ziua.scuzati pentru ca am deschis un subiect nou dar am tot cautat problema mea si nu am gasit strict o rezolvare sau macar un sfat. Masina e un seat ibiza 2002 motor 1.4 16v. trepideaza motorul la relanti si da sa se opreasca dupa cateva secunde...am facut o scanare si mi-au aparut foarte multe erori (pun mai jos scanarea). cred ca ar fi de la modulul de comanda al motorului.verificat bujii,bobine.am fost la service si mi s-au schimbat doua bobine intre ele (eu avand si o eroare de missfire pe cilindru 3) si eroarea tot persista. vor sa umble la supape dar dupa mine cred ca e o problema electrica si nu mecanica.ce sfaturi imi dati?multumesc si scuzele mele pentru un subiect nou.
Saturday,12,January,2019,13:45:50:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ6LZ2R025796 License Plate:
Mileage: 166930km-103725mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ2R025796 Mileage: 166930km/103725miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 AH
Component: MARELLI 4MV 4834
Coding: 00071
Shop #: WSC 80565
VCID: 58BF6EEBB8E6B0DE8C3-4A3A
VSSZZZ6LZ2R025796 SEZ7Z0B1523327
1 Fault Found:
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 00000
VCID: 4189A38F4B7C1116DBD-5072
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 24470A1BE42E243ED0B-5072
5 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
000 - -
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 16540
Shop #: WSC 06402
VCID: 3A7BD46326AA42CE9A7-5072
3 Faults Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00907 - Intervention load Management
35-00 - -
Part No: 6Q0 909 605 R
Component: 06 AIRBAG VW5 0007
Coding: 22838
Shop #: WSC 06441
VCID: 4683B0936252362EEEF-5072
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 820 F
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00147
Shop #: WSC 80565
VCID: 2D51EF3FE7E4E5760F5-5072
4 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01322 - Control Module for Multi-Function Unit (MFA) (J501)
01309 - Power Steering Control Module (J500)
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-50E6
1 Fault Found:
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00111
Shop #: WSC 06402
VCID: 3979CB6F23AC49D693D-5072
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 5q Komfortgerát 0001
Coding: 00259
Shop #: WSC 06402
VCID: 3D71DF7F378475F6BF5-49D8
Subsystem 1 - Part No: 6Q2959802C
Component: 5q Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 6Q2959801C
Component: 5q Tõrsteuer.BF KLO 0001
Subsystem 3 - Part No: 6Q0959811A
Component: 5q Tõrsteuer.HL KLO 0001
Subsystem 4 - Part No: 6Q0959812A
Component: 5q Tõrsteuer.HR KLO 0001
7 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
