E timpul pentru revizia periodica,ne apare tuturor dupa un an sau x mii km. E un interval intre revizii la service. La Cordoba scrie INSP. Se poate reseta, gasesti in manual cum.
La ordoba in manual:
Service interval display
A service pre-warning will appear in the odometer if a service is due soon. A
spanner symbol appears and the display “Km” with the distance that can be
driven until the next service appointment is due. The display will change after
approximately 10 seconds. A clock symbol appears and the number of days
The following message appears on the instrument panel if a service is due:
INSP- Maintenance service
The service message will disappear approximately 20 seconds after the ignition
is switched on or the engine is running. This may also be turned off
pressing the short journey counter reset button for more than 0.5 seconds.2)
The Service Centre who carry out the maintenance service will reset the maintenance
interval display on completion of the service.
We recommend that the repair and maintenance work only be carried out at
Authorised Service Centres.
The service indicator can also be reset by pressing the trip counter button.
Proceed as follows:
- Switch off ignition. - Scoti contactul
- Keep “Reset” button on distance counter pressed. - Apesi butonul de reset kilometri
- Connect ignition with the “Reset” button pressed. The fixed mode
display appears. - Pui contactul
- Release the reset button and rotate it to the right. The display will return
to the normal mode. The indication has been reset. - Dai drumul la buton si rotesti spre dreapta.
