RoshKtu
Vand sonorizare auto! Preturi mici!
21 Mar 2011, 23:09
Statie MTX 4 canale : 300 RON
MTX RT604 Road Thunder 360W Class-AB 4-channel Amplifier
* CEA RMS Power : 4x 90W @ 2 Ohm, THD+N ≤1%
* CEA RMS Power : 4x 60W @ 4 Ohm, THD+N ≤1%
* CEA RMS Power : 2x 180W @ 4 Ohm, THD+N ≤1%
* High pass x-over : 12dB/oct variable from 40 to 400Hz
* Low pass x-over : 12dB/oct variable from 40 to 400Hz
* Signal-to-Noise Ratio (1 watt) : > 80dB
* THD+Noise (Distortion) (1 watt) : ≤ 1%
* Frequency Response (±1dB) : 20Hz-30000Hz
* Maximum Input Signal : 6V
* Maximum Sensitivity : 100mV
* Dimensions : 364 x 180 x 55mm
Subwoofer in incinta Bass Reflex 12" JBL Seria GTO : 250RON
JBL GTO 1204 Subwoofer
* subwoofer in incinta Bass-Reflex
* difuzor GTO 1204, diametru 300 mm
* putere: 300W RMS (1200W max)
* SPL (2.83V/1m): 93dB
* raspuns in frecventa 35 - 300 Hz
* impedanta 4 ohmi
* dimensiuni (H x W x D) 520 x 414 x 370 mm
Subwoofer TUB Boshmann 12" USA SPL : 220RON
Boschmann 12" 500W Subwoofer
12" High Power Subwoofer
Frequency Response: 28Hz~1800Hz
Sensitivity: 92dB
Normal Impedance: 4 Ohms
Peak Power Output: 500 Watts
RMS Power: 250 Watts
PRETURILE SUNT USOR NEGOCIABILE! MOTIVUL VANZARII ESTE UPGRADE!
OFER PROBA DIRECT PE MASINA!!!
Persoana de contact: Cristian
cristian.dumitru88@yahoo.com
0725.505.243
B 123 RHK
SEAT LEON 1.6 16v 105 cai
HONDA Hornet B 599 TOY
:iroc:
RoshKtu
Re: Vand sonorizare auto! Preturi mici!
23 Mar 2011, 09:42
URGENT! Valabil pana duminica!
Statia: 250 ron
Tub boschmann: 150
B 123 RHK
:iroc:
RoshKtu
26 Mar 2011, 21:35
s-a vandut statia MTX si tubul BOSHMANN...
JBL-ul ramane la vanzare 250 RON!
B 123 RHK
:iroc:
RoshKtu
02 Apr 2011, 11:56
s-a vandut! se poate inchide/sterge.
Multumesc! :hi
B 123 RHK
:iroc:
