-lumina lor este "alb curat"...
HOD advantages:
1) Quartz bulbs – Will not explore like glass bulbs.
2) Germany filament – High quality ; will not burn easily.
3) Pressured mixed gas – Reduce heat while increasing brightness to maximum.
4) Ceramic socket – Avoid heat to melt factory’s plastic socket & provide sufficient power with thicker wires.
Distance: The lux of HID(xenon) is shorter than the lux of our HOD. Lux determines the distance for comfortable vision. For example: the low-beam/high-beam is 150~200/500~600 meter on HID, but the low-beam/high-beam on our HOD bulbs is 550~650/950~1000
meter.
Ability to pass through to rain/fog: HOD's wavelength is larger than HID's, so our HOD has better ability passing through rain/fog & therefore, provide better driving comfort.
HIR
Halogen lamp with Infrared Reflective films
Double the intensity of other bulbs with the same power 55w
Perfect UV cut
Increase efficiency by reflecting coating of infrared
Increase life by fill up with Xenon gas 100%
To complete power up for brightness and color performance the filament must be re-heated by reflected infrared.
HIR
HOD
*pret 55 lei setul Hir
*pret 50 lei setul Hod
ovi_ovi7@yahoo.com
0724278316
